Has anyone successfully bump started their GS?
Installed headlights directly to battery and accidentally left them on all weekend! Tried to bump start, and although conditions were not ideal (confined space) i was unsuccessful (used 2nd gear etc). Just interested to see if it's possible? Connected a fully charged portable battery pack and just got the clicking, so connected to car battery and had to keep car engine revs up for 20 minutes before the GS had enough power to fire up. Ok I know it's a dumb thing to do in the first place, but it seems to take so much power to start. Now its started, it starts and runs fine so I think the battery is OK. Has anyone started their GS with a flat battery using a portable battery pack and if so what was the cranking power of the portable pack? Unless I change the wiring for my headlights, I may have this situation again. I don't plan to, but you know how it goes, so I'b be really interested in anything you have to say. Thanks |
If you don't have power to the fuel injection system the injectors won't pump any fuel. If your starter system was dead but the battery you could do it but that's about the only failure where a bump start will work.
