If you pull off the beak and look underneath, you'll see two outlined areas, one on each top of the plastic approximately 3 inches from the ends where they butt up against the fuel tank plastic. I drilled the left side and installed a Powerlet outlet and cap. Powerlet also sells a rubber boot which protects the wiring connections. Use a 15 amp fuse in line to the battery or power panel. I use this for my heated vest and charging accessories.
