Hello Experts,
It seems no matter what I ride, the ride always seems too harsh for my tastes. I probably weigh about 195 all dressed and ready to go. My tire pressures are 32 front and 36 rear. I have the front shock spring preload at 2 clicks from the lightest setting, the rear just below the standard mark and the rebound set at soft. What I really want to know is this: Does the rear wheel setting in any way affect the action of the front wheel? |
Most suspension experts will admit that suspension set up is wee bit
of a trial and error proposition. Fortunately there is quite a bit on the internet about what a lot of people refer to as the "black art" With the GS one of the first rungs of the knowledge ladder is to understand that the dampening valve controls the volume of oil transfer from one side of the shock piston to the other side. This controls the spring primarily on the extension stroke. There is a lot of energy being absorbed and shocks will get warm when put to the test. If you go through a systematic spring pre-load and shock dampening adjustment you should be able to get close to maximizing what your looking for within the design parameters of the bike. Let us know what set up you finally come up with. Last edited by pdxrmccgs; 28-Jul-2011 at 05:48 PM (950). |
Thanks. If I now have the suspension set soft all around, and the front wheel does not bottom, but is not compliant to the smallest road imperfections how can I improve this reaction? Am I wrong in thinking that any move to stiffen the rear will not make the front more compliant?
The only front adjustment available to you is spring pre-load. You can not set the damping on the stock front shock. It sound like you prefer a smaller amount of compression damping. That will require an after market shock. I'd try to take test rides on bikes with after market shocks before spending your money... you may not find the difference (if any) worth the cost.
FWIW freeway expansion joints were jarring with my stock suspension set up correctly. They are not jarring with my after market Ohlins set up correctly (but I can still feel them). |
