wouldnt you know it, a good bath and the damn thing rebels. It seems the horn has shorted and continues to blow upon turning ignition switch on. you can hold horn with hand to muff it and it will quit after about a minute. also the horn button will not activate the horn after it finally quiets. 2005 mod. r1200gs. would like someones input not bull on this. i know i can cut the wires and etc. thanks alan
thanks for input marc as i was not aware of the signal routing. i had unplugged the horn thru the night and replugged it this morn and all is back to normal. will look to see if weather proofing can be applied to the area you mentioned. again thanks for the info. alan
Rick R50 (not slash 2, prior to that), R60/5, R75/5, R60/2 sidecar rig with R90/5 motor, K1200RS, and soon a 2008 GS1200 |
