Like lots of others here I replaced my original bulb at around 6,000 miles. Replaced it with whatever bulb the dealer offered, can't really remember if it was stock or not however, at 50,000+ miles that same bulb is still going strong
Jim happy
I went through two bulbs in a year on a brand new 1200GS. The dealer replace the bulb connection under warranty. They said one of them lil tiny copper thing-a-mijigs connections in the plug was bent. I also had the issue of the headlight flashing on and off as soon as the key was in the start position. The headlight should not come on till after the bike has started. All was solved when they replace the connection
I have not had too much trouble with my 05, but while i was in San Diego a few weeks ago, i picked up a HID kit from 1off Motorsports.
Tell them what model you have and they will make sure you get the right ballast kits, and here is the big plus. They guarantee there parts, Globes included...for LIFE. Inexpensive, fit and forget.
Graham Day. 2005 R1200GS |
