Haynes Manual & Transmission Oil Cap Crush Washer - BMW R1200GS Forum : R1200 GS Forums
Old 04-Jan-2012, 11:57 PM (248)
Default Haynes Manual & Transmission Oil Cap Crush Washer
Two questions:
1- Can someone give an opinion on the new Haynes Service Manual for the GS?
2- Is a Crush Washer used for the Transmission Oil Filler Cap? My dealer says no.
Thank you.
Old 05-Jan-2012, 04:18 AM (429)
Some words from online fiche : This plug has a captivated gasket ring. BMW wants you to replace the plug when you want to replace the gasket ring. A good substitution however is PN 07119963200
Old 05-Jan-2012, 10:55 AM (705)
Haven't seen the "new" Haynes. I've the '04-'06 version. It is OK, but I find I don't look at it much, preferring the RepROM.
What coolrider said about the crush ring except he gave you the part number for the drain, not the fill plug. You can cut the one that's on the plug off and use a standard 18 mm crush ring. Or you can re-use the existing. I've done it both ways on the transmission fill given that it is above the resting oil level.
If my notes are correct the crush rings I use for engine and transmission oil change are:
07 11 9 963 252 Engine oil crush ring (16 mm)
07 11 9 963 200 Transmission oil drain crush ring (14 mm)
07 11 9 963 300 Transmission oil fill crush ring (18 mm)
That's for my '05. Hope I didn't get them backwards. Don't know if things have changed for newer models, either. Sizes are inside diameters.
