Sticking rear brake light. - BMW R1200GS Forum : R1200 GS Forums
Old 21-Jan-2012, 10:46 PM (198)
Ride for ever.
Default Sticking rear brake light.
Being the proud owner of one of the first R1200GS released in 2004 in New Zealand and have clocked up 140,000K's of trouble free motorcycling I have nothing but praise for the bike.
Recently though I have a small issue with the rear brake light sticking on intermittently and as the bike has the powered servo brakes the pump also stays on with the light. I have checked the obvious such as the hand guard fouling the brake lever, plus unplugged the micro-switch and spayed copious amounts of WD40 around the switch and the master cylinder on the handlebars.
To date nothing has fixed the problem so I was wondering if anyone else had brake light issues such as this??
I would be interested in anyone's ideas if you are able to shed some light on the subject. (no pun intended)
Peter.
Old 22-Jan-2012, 11:40 AM (736)
Peter,
Did you also check the switch on the rear brake foot pedal? With a multimeter you should be able to check to see if the switches are opening and closing as expected.
I wish I could be of more help, but I'm new to BMW. If the switches check out OK, it could be a spot where the insulation has worn off a wire, making it seem like the switch is closed.
The wiring diagrams are here, if they would do you any good:
http://www.r1200gs.info/R1200GS-WD2.pdf
John
Old 26-Jan-2012, 09:41 AM (653)
Ride for ever.
Default Rear brake light
Will look at rear brake. Thanks for your help.
Old 08-Feb-2012, 05:32 PM (981)
Send a message via Skype™ to roamingbeemer
Default same problem
I just had same problem with my other beemer. It is was the front brake lever switch that was sticking. I fixed it with heat from a blow drier, wd40, and then contact cleaner. Mine is working fine now but I am watching it.
Old 04-Mar-2012, 04:03 PM (918)
knightrider
Default front brake switch sticking
Strange I should read this as mine takes a spell and does it. I lately after trying spray lubes to no avail, tried putting the bike on the side stand and putting a few drops of pure silicon liquid lube on it. It runs down to the switch over night and this solves the problem so far. The lube I use comes with the Aria helmet for the visor mech. Just a thought as it has worked for me. Alan
