Zumo reccomended to me - BMW R1200GS Forum : R1200 GS Forums
Old 14-Apr-2008, 04:13 AM (384)
Thor's Avatar
Question Zumo reccomended to me
Talking with my BMW dealership they have stopped stocking the BMW sat navs as noone seems to want them except for a few people buying new bikes where the significant costs are addded to finance deals. Instead they recommended to me the Garmin Zumo. Looking at the 500 and 550 models I will try to get a good deal for it on ebay. My question to this forum though is how easy is it to wire up to the GS? Do you just wire it up to the front headlights. I'm prepared to have a go at this myself but have no knowledge of wiring up these things. Anybody have any experience of this?
Thanks
Thor
Old 14-Apr-2008, 08:48 PM (075)
sfarson's Avatar
Custom User Title
Thor, You have several options...
- You can use the battery cable coming with the Zumo to power the Zumo.
- You can buy an inexpensive Zumo-BMW accessory port cable to power the Zumo. (http://www.powerletproducts.com/)
- You can buy a BMW plug to wire to the harness near the steering (where BMW plugs in their BMW Nav GPS's)
- Can run the Zumo off its chargeable battery, though I believe the music functionality will not work off batteries.
HTH.
Old 20-Apr-2008, 10:41 AM (653)
Thor's Avatar
HTH,
Thanks for the advice. I presume with all but the BMW plug then a wire needs to be run from the battery, is this correct? Such a novice I know..apologies
Thor
Old 21-Apr-2008, 09:27 PM (102)
sfarson's Avatar
Custom User Title
Yes. I just did this the other day. Takes about ten minutes. Connect the cable coming with the Zumo to the battery, run it up under the tank to the steering head, tie it down and you're ready to connect it to your mounted Zumo. It's a great device.
Old 22-Apr-2008, 01:54 AM (287)
Smeggy's Avatar
I have a MigSel mount with a short ram arm for my Zumo. I fitted the extra power socket to the beak and ran the powerlead straight to that. There is a hidden plug taped near the headstock which you can tap into which obviously ties into the canbus, but many prefer to simply wire straight to the battery like sfarson has pointed out.
Old 24-Apr-2008, 04:50 AM (410)
Thor's Avatar
Default Many thanks
Good advice guys. I will go ahead and by the Garmin as it all sounds simple enough. Thanks for the photos too.
Cheers
Thor
Old 09-May-2008, 03:40 AM (361)
papawheelie's Avatar
don't trust this guy
The zumo is great. Works perfectly for almost all applications. The only down side is off road. When you use your gps for off road it usually is fine. But if you are well off the beaten path, and you like to save and edit some of your trail riding, some times a different gps may work better. If you plan to spend more time on road, get the zumo.
BMW R1200GS, Ducati Sport 1000 SE, KTM 530 EXC
Old 08-Jul-2008, 12:12 PM (717)
Default Zumo550
Done mine tonight. Funneled garmin power cable to rear and fitted auxilary power socket male - this give you the powered switched option working with your ignition and no pwer drains etc. I am definitly purchasing the extra option of another power outlet fitted at the cockpit as the extra power point is also switched.
