2013 LC ESA Problem - BMW R1200GS Forum : R1200 GS Forums
post #1 of 5 (permalink) Old 01-Mar-2016, 06:50 AM (534) Thread Starter
Kartal Kama's Avatar
2013 LC ESA Problem
Hi all,
I am new in forum but I was following threads for many years. I have a 2013 r1200gs LC, it is the first generation of this product line. On october 2014, first I had the esa problem. When I've started the engine, the yellow error indicator turned on and in the description field esa was written. All the suspension was locked and it was impossible to move. After a few times to stop and re-start the engine, it turned to normal state and suspensions were smooth again. I went to local technical support to check the problem. They connect the bike to the computer but there was no error log on the system.
After 1,5 years later, last week, same problem had occured. Exactly same situation and same solution. I was running about 30 kilometers and I'd stop for refueling on the gas station. After refueling, I've started the engine and esa had locked again. I've called the technical guy and asked him if there is any bike had same problem after 3 years of manufacturing, unfortunately he said that the only esa problem was mine
Lastly; there is no problem while engine is running. It appears after engine starts.
The screen shot of display when the problem had occured is below. If any idea or any heard of similar problem, please say here.
Thanks & Best Regards...
https://www.r1200gs.info/forum/member...8-img-3688.jpg
Kartal Kama is offline
post #2 of 5 (permalink) Old 31-Mar-2016, 12:46 PM (740)
I have a 2013 Gs1200lc and also appear to have an ESA problem.
The suspension adjusts at the start of the run with me two up so showing two helmets, I can feel the bike getting taller as thos happens. All good so far but, laternim the day, after a few stops, the suspension appears to re-adjust when I start the bike and the bike drops in height. The warning symbol for ESA shows in the dash but, if I leave the bike overnight, everything appears fine again umtil the next time.
I will investigate further before visiting a dealer but getting concerned that this is a serious problem
NickDawson is offline
post #3 of 5 (permalink) Old 27-Mar-2018, 06:13 AM (467)
Is there was a problem is it solved now?
bambalona is offline
post #4 of 5 (permalink) Old 27-Mar-2018, 06:38 AM (484)
The first thing to do when an ESA fault displays is to reset/calibrate ESA the system with a GS911 or similar, 99% of the time this will address the issue.
2013 R1200GSW
post #5 of 5 (permalink) Old 14-Jun-2019, 04:32 PM (897)
same problem
Kartal Karma have you resolved the issue? I have a similar issue fault code outstanding is E11438. anyone help please?
Belly650 is offline
