Clutch fluid/oil change.... - BMW R1200GS Forum : R1200 GS Forums
 3Likes
  • 2 Post By Pterodactyl
  • 1 Post By Clay
post #1 of 9 (permalink) Old 21-Mar-2018, 01:10 PM (756) Thread Starter
Question regarding 2015 GS:
Is the clutch oil/fluid supposed to be changed at some interval? I haven't found anything indicating such (yet). Assuming it needs to be changed, are we just talking about the actuating fluid in the reservoir for the clutch lever? What sort of fluid is to be used? Is there a way to bleed that system similar to bleeding the brakes?
Apologies now for my ignorance on this aspect of the bike's maintenance.
Weir1200GS is offline
post #2 of 9 (permalink) Old 21-Mar-2018, 02:12 PM (800)
bmwbob51's Avatar
Water boxer clutch used mineral oil and doesn't absorb water like brake fluid. I've never seen anything on changing clutch fluid.
bmwbob51 is offline
post #3 of 9 (permalink) Old 21-Mar-2018, 02:19 PM (805)
Like BMWBOB says the clutch actuator system uses mineral oil and there is no recommended change interval by BMW.
I will add though to keep an eye on the fluid level in the reservoir, my 2013 had a very, very slight seep at the fitting coming out of the reservoir and by the time I discovered it the reservoir was nearly dry and there was almost no visible oil around the area.
2013 R1200GSW
post #4 of 9 (permalink) Old 21-Mar-2018, 04:38 PM (901)
Survivor
Pterodactyl's Avatar
It will be a very good decision to invest in the BMW service manual. they come on CD/ROM and will answer all your maintenance questions. At the very least get a Haynes repair manual, and better yet get both. You will be very happy if you do.
ExHarley Rider and JetSpeed like this.
Kevin
The Outpost, Silver City, Montana
Team Pterodactyl
2018 Ural Gear Up, 2017 R1200GSA
Pterodactyl is offline
post #5 of 9 (permalink) Old 22-Mar-2018, 06:27 AM (477)
Dealer service manager and another independent mechanic told me that there are basically only 2 reasons to change the hydraulic clutch fluid: 1) the clutch needs to be repaired and its a good idea while its open. 2) As JetSpeed mentioned, there is a leak/seep or other loss of fluid. There is no regular or scheduled maintenance necessary.
Cliff
Lincoln County, NC, USA
ExHarley Rider is offline
post #6 of 9 (permalink) Old 22-Mar-2018, 07:09 AM (506) Thread Starter
Thanks, guys, and yes, I have the repair manuals, which is what lead me to ask the question because I didn't see anything in there indicating the fluid should be changed. So, in light of that, and given your good responses, I'll just open the reservoir periodically and make sure it's still full of mineral oil. Again, thanks.
post #7 of 9 (permalink) Old 22-Mar-2018, 09:15 AM (594)
That is interesting..there is no viewable sight glass on the clutch reservoir, on these current WC versions, instead by opening the top plate thus leading to possible contamination though it is mineral oil based...
Weir1200GS likes this.
Clay is offline
post #8 of 9 (permalink) Old Yesterday, 09:34 PM (107)
OKU
what type pf mineral oil can be used......any BMW spec or recommendation
happyintruder is offline
post #9 of 9 (permalink) Old Today, 11:08 AM (672)
BMW used to use a Magura product -- Magura Blue Blood. Don't know if that is what they are using on current bikes.
marc is online now
