Engine trouble after fill up - BMW R1200GS Forum : R1200 GS Forums
 7Likes
post #1 of 16 (permalink) Old 02-Mar-2019, 12:41 AM (279) Thread Starter
Hello,
I finally purchased my dream bike, a 2009 R1200GS, So Iím pretty new to here.
My trouble is that all 5 times that Iíve filled up my tank to full the engine hesitates, idles low or rough and remains the same until I arrive home. I would need to rev up the throttle at red lights to keep it from stallling. When I get home thereís a slight smell (I could swear it smells like gun powder or something burning).
The bike rides perfect before and the day after all of this, so it really has me stumped. Maybe it idles low for a second the day after but it finds its place right away.
Any thoughts?
Thanks!
Heyrick69 is offline
post #2 of 16 (permalink) Old 02-Mar-2019, 09:19 AM (638)
LAS
Sounds like a vacuum problem. Gas tanks have to breathe. Most likely your gas tank has a clogged vent or the charcoal canister is flooded with gas. These are both easy to check and to remedy. One easy way to see if this is your problem is to leave the gas cap open after a fill up to see if the problem reoccurs.
Joe Bar likes this.
LAS is offline
post #3 of 16 (permalink) Old 02-Mar-2019, 09:39 AM (652)
Super Awesom Person
I would pull the gas tank and inspect all fittings and blow out all hoses. The purge (or tank vent) valve is probably sticking open so inspect that.
https://advrider.com/f/threads/wtf-i...-valve.732481/
Rick
2018 R1200GS
Rick92040 is offline
post #4 of 16 (permalink) Old 02-Mar-2019, 11:45 AM (739)
LAS
If the easy stuff fails, pulling the tank would be on my list of things to look at, but it would not be my first move or even my first move if the easy stuff didnít yield favorable results.
LAS is offline
post #5 of 16 (permalink) Old 02-Mar-2019, 12:11 PM (757)
Super Awesom Person
Perhaps pulling the tank is a bit drastic. I just wanted to make sure he cleans all the hoses.
LAS likes this.
Rick
2018 R1200GS
post #6 of 16 (permalink) Old 02-Mar-2019, 05:35 PM (982)
Survivor
Pterodactyl's Avatar
The clogged vent hose or flooded charcoal canister diagnosis fits the symptoms better than problems under the tank. My money is on the canister being flooded. Easy to remove permanently.
Pterodactyl is offline
post #7 of 16 (permalink) Old 04-Mar-2019, 03:41 PM (904)
Houdini's Avatar
Are you over-filling? ...... flooded canister?
Current: 2013 R1200GS LC
Houdini is offline
post #8 of 16 (permalink) Old 07-Mar-2019, 12:40 AM (277)
bobz
Engine hesitation ideas
Originally Posted by Heyrick69 View Post
Hello,
Any thoughts?
Thanks!
Just an idea, does it only do it when the tank is full- really full. If you over fill a tank ( or normal filling and let it sit with a hot motor or on hot day ), the excess fuel goes into the vapor recovery canister and into your engine making it very rich for a while. Vapor recovery systems usually handle vapor, but now it handling liquid and it runs into the engine. This happen pretty regularly on my Harley. If I fill it to the top and then immediately stop for lunch. The gas expands from the heat of the engine and up into the vent tube and into the vapor canister. Then after lunch I would start the bike and it would stall in the middle of the intersection. If I don't over fill the tank and/or fill up after a long road break, it never happens. Just a suggestion.
ExHarley Rider and jaxon like this.
bobz is offline
post #9 of 16 (permalink) Old 07-Mar-2019, 07:47 AM (574)
Super Awesom Person
I hope the guy comes back and lets us know if he fixed it or not.
Rick
2018 R1200GS
post #10 of 16 (permalink) Old 07-Mar-2019, 09:09 AM (631)
Senile Member on 2006 GS
Does anybody ever do that?
saughblade is offline
So, where's the transmission drain and fill plugs? roscoe_rules Maintenance and Modifications 4 08-Mar-2015 10:08 AM (630)
R1200GS (2013) Frame In-fill Panels bobsbikestuff Dealers and Vendors 0 20-Sep-2013 03:39 AM (360)
Hugger/Extenda/Frame In-Fill Panel Package Deal bobsbikestuff Dealers and Vendors 0 18-Dec-2012 09:16 AM (636)
Gas Fill Cap Woes JimmmyV General chatter 4 17-Jul-2010 10:54 PM (162)
Fill Your Tank Today bankarty General chatter 3 01-Mar-2008 04:48 AM (450)
