engine shuts down - BMW R1200GS Forum : R1200 GS Forums
 1Likes
  • 1 Post By wegger
post #1 of 4 (permalink) Old 25-Mar-2019, 02:34 AM (315) Thread Starter
engine shuts down
I have a problem with my 2007 1200GS: the engine shuts down randomly. This often happens when I accelerate and close the throttle to shift to higher gear. The problem also occurs when closing the throttle while riding down a hill. It usually occurs at the beginning of a ride, even if I rode before (so the engine is not cold), usually in the first mile or two. If you keep the rpm low - less than 3,000 rpm, even if you go into high gear, the fault appears less. I took it to my mechanics and they replaced the spark plugs, secondary coils and the Throttle Position Sensor, it was good for few hours (and the engine was running smoother...) and then the problem appeared again the day after. I returned to them and they replaced the primary coils, but the problem is still there, even though it seems that it occurs less then before.*
Any suggestions?*
ahendler is offline
post #2 of 4 (permalink) Old 25-Mar-2019, 06:35 AM (482)
jaxon's Avatar
Any suggestions?*
I had a '08 R1200RT that did the same thing. Some say it's the fuel pump controller and some people do a bypass or a new one. It gets moisture in it and causes an erratic shutdown. Sometimes the side stand switch is rumored to be the culprit.
https://www.hexcode.co.za/techinfo/e...ump-controller
https://burnsmoto.com/products/bmw-m...p-bypass-cable
2017 R1200GS
1992 K75S
2013 G650GS
jaxon is offline
post #3 of 4 (permalink) Old 25-Mar-2019, 02:32 PM (814) Thread Starter
[quote=jaxon;287063]I had a '08 R1200RT that did the same thing. Some say it's the fuel pump controller and some people do a bypass or a new one. It gets moisture in it and causes an erratic shutdown. Sometimes the side stand switch is rumored to be the culprit.
Thanks Jaxon, how was the problem on your bike solved?
ahendler is offline
post #4 of 4 (permalink) Old 05-Apr-2019, 02:27 PM (811)
wegger's Avatar
I have a problem with my 2007 1200GS: the engine shuts down randomly. This often happens when I accelerate and close the throttle to shift to higher gear. The problem also occurs when closing the throttle while riding down a hill. It usually occurs at the beginning of a ride, even if I rode before (so the engine is not cold), usually in the first mile or two. If you keep the rpm low - less than 3,000 rpm, even if you go into high gear, the fault appears less. ... clipped...
Any suggestions?*
I was having a very similar problem. 2008 1200 with appx 98k miles. It first happened once on a day ride, accelerating through 2nd gear, maybe 5k rpm, and it just shut down, then almost immediately started back up. I thought the throttle might have slipped my grip. It did it again just a few miles later and this time I had time to notice that the dash and instruments went off and came back on like it just rebooted. Does this sound familiar? Over the next month it started happening more frequently. I went through all the dash, ecu, and fuel pump connections, cleaned and put dielectric grease on them. Found no problems. Jiggling the ignition key switch had no effect. I thought it might be the key or the key chip sensor. I finally took off the ignition switch cover below the top triple clamp, checked the wires, then removed the switch module and jiggled it around, and it caused the ignition to come on/off intermittently. Boom! The plastic ignition switch module had just worn out. Found a used one on Beemer Boneyard for $60. Cheap fix, and it solved all the problems.
Hope this helps.
Niks likes this.
wegger is offline
Tags
engine shuts down
Engine/Bike shutting down/total loss of power while in motion robbo997 Maintenance and Modifications 3 03-Nov-2016 04:54 PM (912)
Engine bogging down after shifting (sometimes) wallace912 Maintenance and Modifications 4 19-Sep-2014 02:14 PM (801)
My GS shuts down... when it feels like it!!!!! orsolomeo General chatter 8 21-Mar-2014 09:16 AM (594)
Keeping the front wheel down.... Schtum General chatter 10 24-Jul-2007 04:54 PM (912)
Long Way Down HMarc Traveling tales 0 19-May-2007 09:02 AM (584)
