Looking at a used GS. Need advice. - Page 6 - BMW R1200GS Forum : R1200 GS Forums
 34Likes
post #51 of 59 (permalink) Old 17-Apr-2019, 11:39 AM (694)
Originally Posted by saughblade View Post
BTW, there may be a "grub screw" in one of the front calipers instead of a bleeder. Apparently they came from the factory that way (something to do with how the system was initially filled).
I'd forgotten about that. FWIW my May 2005 build GS had real bleeders, not grub screws. It may be only the earliest bikes that didn't get bleeders.
marc is offline
post #52 of 59 (permalink) Old 17-Apr-2019, 12:00 PM (708) Thread Starter
Crawgator's Avatar
Thanks! Both of the front calipers have bleeders so good to go there. How much fluid did you use in changing? I have one pint but Jim's vids say 2 so I plan to pick up another pint today.
Both use 1/4" tubing. The bleeders themselves are different sizes: the ones on the module are 7mm, while the ones on the calipers are 8mm. Do yourself a favor and get a six-point box wrench (or socket) for both; it really sucks to round them off, and it sounds like yours have had a lot of time to get sticky.
BTW, there may be a "grub screw" in one of the front calipers instead of a bleeder. Apparently they came from the factory that way (something to do with how the system was initially filled). Almost everybody removes the grub screw and replaces it with a bleeder as part of the first flush... if you find the grub screw in there, it might be indicate the previous owner(s) never flushed the brake system... ugh...
08 Goldwing 1800
12 Ural Patrol
Crawgator is offline
post #53 of 59 (permalink) Old 17-Apr-2019, 05:51 PM (952)
OKU
Originally Posted by Dr. Strangelove View Post
>> If the servo unit does go tits up they can be rebuilt for significantly less than BMW charges <<
if that is a model ModuleMasters works on. I would give them a call to be sure.
also, does this bike have a float or the dreaded fuel strip?
and was the 05 GS out of the woods for clutch splines??
i believe all 2005s have that fucking fuel strip......mine did and was a pain in the ass
happyintruder is offline
post #54 of 59 (permalink) Old 17-Apr-2019, 06:10 PM (965)
OKU
Originally Posted by Crawgator View Post
HAHA! So far so good. It is still a bit hesitant to start. I have started it 4 times now and the best way seems to be to turn key on, wait for everything to cycle thru and hit the starter and hold for 2-3 seconds and release. Then turn key off and back on and repeat and it fires right up after that. It has a bit of a rough idle for about 3 seconds then smooths out. I plan to try and flush the brakes today then I'll take it for a short ride and give it a chance to heat up easy.
i think my issues with the bike was i failed to let it cycle thru before i started it....
post #55 of 59 (permalink) Old 17-Apr-2019, 06:49 PM (992) Thread Starter
Crawgator's Avatar
This 05 has a float. I just got home a few minutes ago. Last time I cranked was around 10 am today. I turned on, let it cycle thru and hit the starter. It started right up with a bit of a stumble on idle. Blip throttle slightly and it smoothed out. Progress! Maybe the Pure gas, Seafoam and Techron fuel injector cleaner cocktail is breaking up whatever minor varnish may have been in the motor.
Sent from my iPad using Tapatalk
08 Goldwing 1800
12 Ural Patrol
post #56 of 59 (permalink) Old 17-Apr-2019, 07:12 PM (008)
Dr. Strangelove's Avatar
@Crawgator where are you located? In local lingo, wher' you stay(in at)? If, as your name suggests, a fellow primeval swamp thing, you may enjoy this:
Dr. Strangelove is offline
post #57 of 59 (permalink) Old 17-Apr-2019, 07:45 PM (031) Thread Starter
Crawgator's Avatar
Laissez les bon temps rouler! My family is from around Plaquemine and Plaquemines Parish! I like not far from there now.
https://www.youtube.com/watch?v=smIoj1DDQh0
Dr. Strangelove likes this.
08 Goldwing 1800
12 Ural Patrol
post #58 of 59 (permalink) Old 19-Apr-2019, 07:51 AM (535)
Senile Member on 2006 GS
First time I changed the fluid, I bought a bottle of LiquiMoly fluid from Beemer Boneyard (along with their special funnel); it was 1/2 liter or just a bit more than a pint. It was just barely enough. Second change, I just picked up a quart of fluid at the local Advance Auto store. I probably used a bit more than half of it. So I have a bit less than a pint of leftover fluid that will not be any good in two years... but that quart at Advance Auto was cheaper than the three six-ounce bottles the local bike shop wanted to sell me...
BTW... if you do not have this funnel, you can fake it with a regular funnel and some black tape, but the BeemerBoneyard item does make the fluid change a bit more pleasant.
Crawgator likes this.
saughblade is offline
post #59 of 59 (permalink) Old 21-Apr-2019, 07:47 PM (032) Thread Starter
Crawgator's Avatar
Finally had time to work on bike this weekend. I pulled brake calipers and removed pads and checked. Plenty of meat left in all of them. They hardly look worn. I cleaned calipers and the pins with brake cleaner. Lubed pins with anti seize and coated the back of pads with anti squeal and reassembled. I flushed per Jim's excellent DVD's. Tested using GS911 brake bleed test and the rear failed. Bled the circuit and the calipers again. This time I got them to pass but I had to really push HARD on the rear brake pedal. Front passed as well but I had to pull lever really hard to get it to pass.
Took for a test spin. Fronts grab hard and fast with little movement. Rear you have to depress the brake pedal quite a ways but at the end of a long downward foot pedal stroke it will grab hard enough to skid and engage ABS. So my question is, should I have to push that far down on rear brake to get it to grab hard? It begins to slow a bit as soon as you engage but to get it to stop you have to almost bottom out the foot pedal.
08 Goldwing 1800
12 Ural Patrol
need used GS advice Rtm58 General chatter 4 14-Nov-2016 05:27 PM (977)
Looking at buying used 2014 GSA Harley General chatter 7 18-Oct-2015 06:03 PM (960)
Need advice about buying used. bearman1964 General chatter 5 06-Oct-2014 10:31 AM (647)
New or used gs, advice. Crashbar General chatter 9 29-May-2013 02:29 AM (312)
