Clutch slipping under acceleration... - BMW R1200GS Forum : R1200 GS Forums
 1Likes
  • 1 Post By marc
post #1 of 2 (permalink) Old 19-Apr-2019, 08:06 AM (546) Thread Starter
R1200GS 2006. 40,000 miles
Wonder if anyone can help, my clutch has started slipping under above average acceleration.
I've removed the clutch to inspect, however there is plenty of life left in the clutch.
Clutch was dry, no signs of oil... I'm presuming pressure plate failure? or could this be an actuation slave cylinder issue?
Edit: The clutch lever was not hitting the hand guard.
TonkaTruck is offline
post #2 of 2 (permalink) Old 19-Apr-2019, 03:46 PM (865)
Wow. Getting to the clutch is a lot of work.
Did you happen to pop the top of the clutch master cylinder? Was the fluid above the max level?
As the clutch wears the fluid rises in the cylinder. If you didn't reduce excess fluid (I check mine every service) the effect will be as if the clutch were partially engaged. That can cause slippage at high loads.
Revilok likes this.
marc is offline
Bmw r1200 gsa 2017 gear leveler vibrates on acceleration Marshall General chatter 5 09-Oct-2016 10:37 PM (150)
engine vibration under acceleration Drover Maintenance and Modifications 7 30-Sep-2016 07:59 PM (041)
gs 1200 clutch slipping under hard acceleration gs12pilot Maintenance and Modifications 7 03-Oct-2012 08:21 PM (056)
Slipping clutch at higher speeds bellyurchin General chatter 4 28-Jul-2010 05:07 AM (422)
2004 R1200GS Acceleration Issue celticbeemer General chatter 17 30-May-2007 03:13 PM (842)
