GS won't start, won't turn over, display goes dead - BMW R1200GS Forum : R1200 GS Forums
 1Likes
  • 1 Post By Tom Thornbury
post #1 of 7 (permalink) Old 12-May-2019, 08:44 AM (572) Thread Starter
Hi
My crusty 2005 r1200gs won't start. When I turn the key I get DWALO code, then when I press the starter button it makes one thunk, then the display goes dead. The display stays dead until I disconnect and reconnect the battery. The engine doesn't turn over and it doesn't make a starting sound. The battery is new and I was out on it recently so it should have some charge. Any ideas? TIA.
Tom Thornbury is offline
post #2 of 7 (permalink) Old 12-May-2019, 09:05 AM (587)
Crucian's Avatar
Mr Google says that is an internal Alarm Low Battery code. Assuming this is correct and you have an alarm there are two CR123A batteries in the Alarm box, under the seat. How or why this would prevent the bike from starting....no idea.
Was that code displayed on the instruments or the result of a GS911 scan? If you haven't scanned it for fault codes locate a scanner and see what you get and or if you have an alarm module, change the batteries and see what happens?
Crucian is offline
post #3 of 7 (permalink) Old 12-May-2019, 09:58 AM (624) Thread Starter
Cheers. I should have mentioned the code was for the alarm (I googled it too). The code was on the instrument panel. I will replace those batteries asap. I was wondering if the alarm battery could possibly affect the starting of the bike. Is there any reason why an alarm with a low battery might automatically shut the bike down? Sorry I'm a bit of a dunce on electronics...
post #4 of 7 (permalink) Old 12-May-2019, 12:17 PM (720)
LAS
Charge the battery or jump start that the battery is new and you recently rode the bike doesn’t mean that something did not drain the battery or that it has not failed.
LAS is offline
post #5 of 7 (permalink) Old 12-May-2019, 06:34 PM (982)
Senile Member on 2006 GS
According to this post at ADVrider, low batteries in the alarm module shouldn't keep the bike from starting, as it's a CANbus bike and the immobilizer function is provided by the occasionally-troublesome EWS ("Engine Won't Start") antenna and chip key. However, as Abe Lincoln said, you can't believe everything you read on the internet, so by all means try changing the alarm batteries and tell us what happened!
saughblade is offline
post #6 of 7 (permalink) Old 13-May-2019, 11:43 AM (696)
Check the battery terminals for loose connections.
Tanque 55
79 Super Glide
99 KLR
2015 Street Glide
2009 GSA
post #7 of 7 (permalink) Old 14-May-2019, 02:08 AM (297) Thread Starter
I got it started. It is the battery. It's only a few months old but it must be dead. Many thanks for all your help.
Crucian likes this.
Auxiliary Lights Won't Turn OFF cohcdt Maintenance and Modifications 1 12-May-2016 11:58 AM (707)
2007 R1200GS - Tried to Start, Now Totally Dead BrokenPoet Maintenance and Modifications 2 13-Mar-2016 04:04 PM (878)
2006 GS Won't start!!!!! Steelback3 Maintenance and Modifications 4 10-May-2015 03:38 AM (360)
front end goes light oscarcat-2 Maintenance and Modifications 7 04-Jan-2014 08:57 AM (623)
Start button dead. Bike won't start. Ken General chatter 9 07-Jun-2011 01:29 AM (270)
