GSA 1250 Battery Cover - BMW R1200GS Forum : R1200 GS Forums
 4Likes
  • 2 Post By John B
  • 1 Post By CallanderGS
  • 1 Post By JMB711
post #1 of 5 (permalink) Old 14-May-2019, 05:33 AM (440) Thread Starter
Bluec10's Avatar
So, my battery on my 2019 R1259 GSA went dead. I took out the battery to charge it and I canít get the plastic battery cover back on. It doesnít fit behind the frame rail. Is there any trick to getting this thing back on?
Bluec10 is offline
post #2 of 5 (permalink) Old 15-May-2019, 10:23 PM (141)
Hi,
Yup - those covers are a pain.
Firstly - ignore the operators manual
1. Slide the battery out a bit (terminals all connected of course)
2. Slip the bottom part of the cover under the battery and push battery into its spot all the way.
3. I then push the LHS of the cover onto the locating pin and and down at the same time push forward towards the battery and then slide the RHS on to the locating pin. It feels like you will snap the damn thing but it does not.
Hope this makes sense. The 1250 is a beautiful machine.
Cheers,
John
dcysurfer and LAS like this.
John B is offline
post #3 of 5 (permalink) Old 16-May-2019, 04:38 AM (401)
battery cover
Another tip I have learned the hard way over the years is to put a small dab of grease on the locating pins of side covers, it really pays off when removing stubborn, fragile plastic covers.
dcysurfer likes this.
CallanderGS is offline
post #4 of 5 (permalink) Old 17-May-2019, 08:38 AM (568)
Wink
I use a little spit on the tab holes...Haven't broken a pin on any bike since 1978.
JMB711 is offline
post #5 of 5 (permalink) Old 18-May-2019, 09:28 AM (603) Thread Starter
Bluec10's Avatar
Yikes
The bike is my first experience with BMW. My impression is that everything is very precisely designed - a plus. The downside is that knowing how to put the thing back together requires the same precise knowledge. Thanks for your help - Iíll give it another try.
Bluec10 is offline
New member and I'm buying a 1250 (well was!!!) James Davies New Member Introductions 10 03-Apr-2019 06:34 AM (482)
2019 1250 GSA - anyone else with a slight oil leak? BikerPaul General chatter 17 13-Jan-2019 05:50 AM (493)
Putting back the battery cover on 2017 GSA rockhopper Maintenance and Modifications 14 05-May-2018 10:49 PM (159)
New 1250 boxer engined RT spied. Boringoldfart General chatter 25 22-Mar-2018 11:24 AM (683)
Oil seeping from timing cover (alternater cover) chips General chatter 0 06-Jul-2009 05:09 PM (923)
