Bad air valve on cast wheel? - BMW R1200GS Forum : R1200 GS Forums
 2Likes
  • 1 Post By ExHarley Rider
  • 1 Post By Dr. Strangelove
post #1 of 4 (permalink) Old 10-Jun-2019, 06:29 AM (478) Thread Starter
R27
On my 2013 GS with cast wheels, the the schrader valve is located on one of the cast spokes, and faces out, which is quite handy. However, the one on the back wheel will no longer accept air. It will release air (now down to 10 psi), but i can't add any. I've tried two different chucks, on my compressor hose, and neither will inflate. They both work fine on the front wheel. Any thoughts?
Thanks,
Mike
2013 R1200 GSW
R27 is offline
post #2 of 4 (permalink) Old 10-Jun-2019, 07:23 AM (516)
Replace the core on the "bad" valve. This does not require removal of the tire. If that doesn't work, the valve stem can be replaced, this does require removal of the tire.
Southpaw likes this.
Cliff
Lincoln County, NC, USA
ExHarley Rider is offline
post #3 of 4 (permalink) Old 10-Jun-2019, 08:01 AM (542)
Dr. Strangelove's Avatar
many air caps have a valve stem tool on the top, including the caps used for schraeder valves on bicycles. It looks like a short notched extension
Sometimes a valve stem loosens, they just screw in.
Any valve stem can work, including those from old bicycle inner tubes, I keep some spares around.
That is the first thing to check and likely the culprit.
Often when tires are changed the tire is deflated by removing the valve stem. It must be properly tightened to hold air.
Dr. Strangelove is offline
post #4 of 4 (permalink) Old 12-Jun-2019, 07:40 AM (528) Thread Starter
R27
Thanks, Cliff & Dr. Strangelove. Valve core was defective. Easy fix!
Mike
2013 R1200 GSW
R27 is offline
