Tire pressure alarm - BMW R1200GS Forum : R1200 GS Forums
post #1 of 6 (permalink) Old 04-Sep-2019, 07:08 PM (005) Thread Starter
Tire pressure alarm
What is the deal with the tire pressure monitoring system alarms on my 2015 GS 1200 Adventure. I have the correct tire pressure showing 42 LB the air temperature outside was between 59 and 92 F and the alarm showing 33 lb how do I calibrate that alarm so that it doesn't come in and it shows the correct pressure?
Gunhog is offline
post #2 of 6 (permalink) Old 04-Sep-2019, 07:56 PM (039)
Ryno23's Avatar
Only way I know to disable the RDC is to switch to Enduro or Enduro Pro. I had a similar issue with my off road tires that had a max PSI of 35. Fine for front tire, but everytime RDC showed 33.5 for psi in rear tire a fault would pop.
Ryno23 is offline
post #3 of 6 (permalink) Old 04-Sep-2019, 08:20 PM (056)
Kam
When I add air to the tires, I do the following -
1. Tires are cold (eg. Morning)
2. Note the temperature where the bike is sitting
3. The 42/36 is based on 20C/68F
4. For every 10 degrees F above 68, add 1 extra psi. So the cold rear at 78f should be pumped up to 43
5. For every 10 degrees below 68f, subtract 1 psi. Cold rear at 58f s/b 41psi
6. Steps 4+5 account for density based on temp
See if that stabilizes the psi...
Kam
Kam is offline
post #4 of 6 (permalink) Old 05-Sep-2019, 12:26 AM (227)
PoppyGreg's Avatar
flat batteries on the RDC?
I know its a '15 but stranger things have happened...
PoppyGreg is offline
post #5 of 6 (permalink) Old 08-Sep-2019, 11:12 AM (675)
Did this just start? Im guessing that maybe the sensor battery is going low?? I dunno??? Ive a 17 GSA and am not overly impressed with the TP system and will (if its possible) have my dealer turn it off.
JMB711 is offline
post #6 of 6 (permalink) Old 08-Sep-2019, 09:31 PM (105)
ian604's Avatar
Low battery
Low battery Will cause all sorts of problems if youíre adventurous you can get the batteries they are about six bucks apiece and a little silicone and soldering and you can fix your sensors if they drop a quarter of a volt sometimes they will take 10 miles to come on or donít come on at all I have change batteries on both of my sensors I have a 2015 R1200GS The battery are. (Maxwell CR2050HR ) Plenty of videos on YouTube how to fix your sensors better than paying $200
ian604 is offline
