12v power point - BMW R1200GS Forum : R1200 GS Forums
 5Likes
post #1 of 11 (permalink) Old 08-Mar-2019, 06:37 AM (526) Thread Starter
12v power point
Hi
My 12v power point will not power my 12v air compressor?
It just cuts out when I switch the compressor on.
Is this normal? Any ideas?
Dave
post #2 of 11 (permalink) Old 08-Mar-2019, 06:44 AM (531)
bmwbob51's Avatar
Southpaw and LAS like this.
bmwbob51 is offline
post #3 of 11 (permalink) Old 08-Mar-2019, 09:00 AM (625)
'05 R 1200 Gs
Southpaw's Avatar
Originally Posted by [email protected] View Post
Hi
Dave
Yes. 5 amps max load exceeded. Battery direct only.
Rick92040 and LAS like this.
'05 1200 GS
Southpaw is offline
post #4 of 11 (permalink) Old 08-Mar-2019, 10:45 AM (698)
LAS
To amplify, any device that you connect to your bike that has a 12 volt power requirement of over 5 amps will exceed the limit of the bikeís CANBus system. You can bypass the system by connecting your 12volt device directly to the battery or a connection such as a PDM60 or Neutrino that has a built in relay. Most folks add an extra 12 V oultlet to their bikes, which they onnect that way for tire pumps, heated gear, battery tenders etc. Many dealers do so automatically at time of purchase as a courtesy.
LAS is offline
post #5 of 11 (permalink) Old 08-Mar-2019, 11:23 AM (724) Thread Starter
Thanks guys.
Guess Iím going to fit a direct 12v socket to my battery.
post #6 of 11 (permalink) Old 08-Mar-2019, 03:12 PM (883)
66 years old and still 16
boxter's Avatar
The lead Bob shows is the best plug, convert your pump to it and you can hook up an Optimate anytime too.
Ged
boxter is offline
post #7 of 11 (permalink) Old 09-Mar-2019, 01:46 AM (324) Thread Starter
Thanks Ged
Are details allowed on this forum?
Probably not. Can you pm them?
Thanks
Dave
post #8 of 11 (permalink) Old 09-Mar-2019, 04:20 AM (431)
I've got a lead like Bob posted on my bike for using the Battery Tender and I've got a cigarette lighter-type plug that goes into the end of the lead for connecting my compressor. Came from Amazon, naturally.
judgedelta is offline
post #9 of 11 (permalink) Old 09-Mar-2019, 10:58 AM (707)
WARNING:
Some battery tender leads are quite thin as a typical tender draws an about 1 1/4 amp. The leads may have a 2 amp or a 3 amp fuse. A compressor will draw 7ish amps or more. Make sure the harness to the battery can handle at least 10 amps and is fused accordingly.
I use a harness that was made for heated riding gear. It can handle the draw of my compressor.
Another solution is to re-wire the stock accessory outlet such that it is directly connected to the battery.
Southpaw likes this.
marc is offline
post #10 of 11 (permalink) Old 29-Mar-2019, 05:14 PM (926)
capngeo's Avatar
Originally Posted by bmwbob51 View Post
What's the amperage rating on that? So many of those are 18ga and not really up to 10A continuous.
2017 R1200GSA Low Suspension
2012 K1600GTL
2005 Harley VRod
capngeo is offline
12V accessory outlets' locations brumbackkid General chatter 6 29-Mar-2019 05:26 PM (935)
1200GSA Onboard Power Socket has lost power enzo5000 Maintenance and Modifications 4 12-Oct-2017 04:40 PM (903)
Auxiliary Light Attachment Point? Ryno23 Maintenance and Modifications 10 20-Aug-2017 06:30 PM (979)
Purchasing the WC in the first year of production - another view point cycleguy64 General chatter 6 23-Jul-2013 02:33 PM (815)
BMU WEDNESDAY RIDE 21/7/2010 Sublime Point BMBEN Traveling tales 0 24-Jul-2010 10:52 PM (161)
