Question on tubes ? - Page 2 - BMW R1200GS Forum : R1200 GS Forums
 2Likes
post #11 of 15 (permalink) Old 21-Mar-2019, 06:24 AM (475)
Survivor
Pterodactyl's Avatar
Kevin
The Outpost, Silver City, Montana
Team Pterodactyl
2018 Ural Gear Up, 2017 R1200GSA
Pterodactyl is offline
post #12 of 15 (permalink) Old 21-Mar-2019, 07:00 AM (500)
One of the original questions was: What size tube to suffice for both/either wheel? Anyone want to give a guess? Also, the holes in the rims for the TPMS are larger than regular valve stem holes. I suppose this would make no difference. Thanks, JD
judgedelta is offline
post #13 of 15 (permalink) Old 21-Mar-2019, 03:22 PM (849)
The off-center valve position is not an issue. Here is a
link from someone who has experience with tubes in tubeless rim. I've been meaning to pick up a tube as well. The size that I was going to get is 3.5"-4.1" x 18". I can't verify with 100% certainty that it's the correct since as I haven't tried yet and I can't remember where I read this was the correct size.
Phil8dirt is offline
post #14 of 15 (permalink) Old 21-Mar-2019, 03:31 PM (855)
It might be a good idea to have a valve stem fishing tool in the tool kit as well. The fishing stem has to be a male end that threads in once the valve core is removed, if you try and use a fishing stem with a female end that threads on the outside of the valve it won't fit through the valve stem hole on the rim.
post #15 of 15 (permalink) Old 27-Mar-2019, 01:09 AM (256) Thread Starter
Mattbris's Avatar
Thanks for all the replys
Mattbris is offline
Tubes or tubeless? Southpaw Tires (Tyres) 10 12-Nov-2018 06:54 AM (537)
Venting fork tubes Nate Maintenance and Modifications 0 31-May-2016 04:30 AM (395)
Fork tubes sirpolex Maintenance and Modifications 2 19-Nov-2015 11:18 AM (720)
look the exhaust tubes Kgamantini Maintenance and Modifications 2 22-Apr-2015 12:34 PM (732)
What is the Distance Between Fork Tubes? civicblade Maintenance and Modifications 0 30-Apr-2013 06:55 AM (496)
