Noise from front of bike - Page 2 - BMW R1200GS Forum : R1200 GS Forums
 5Likes
post #11 of 17 (permalink) Old 09-May-2019, 12:35 PM (732)
tire scream
Yep my 2017 Michelin tires scream too...I can hardly wait to chuck em!
Southpaw likes this.
JMB711 is offline
post #12 of 17 (permalink) Old 10-May-2019, 03:05 PM (837)
front end noise
Its not the tires, not the windshield, its the whole package. I have tried different combinations of tires and windshields and it never goes away. I am using Michelin road pilot 4 GT tires and despite the 100% road bias the noise is still there esp from 40 to 90 kph.
CallanderGS is offline
post #13 of 17 (permalink) Old 17-May-2019, 06:37 PM (984)
I think it's tire noise that the body work just amplifies. The fork opening acts as a megaphone, directing the tire noise right up into your helmet. The more aggressive the tread, the worse the noise. I notice it on my 16 model, even with Pilot Road 4 street tires. You can get the same "tire noise" from most bikes when the front tire is worn and cupped when you lean into a turn. I hear the "zzzzzzz" of the front tire cornering any bike when the front is worn.
Motormike is offline
post #14 of 17 (permalink) Old 18-May-2019, 12:11 AM (216)
PoppyGreg's Avatar
hmmm
I'm calling werewolves...
PoppyGreg is offline
post #15 of 17 (permalink) Old 19-May-2019, 07:06 AM (504)
Originally Posted by jdanek View Post
Hi,
I'm experiencing the same issue on my '15 R1200GSA ... really annoying howling noise coming up through tank opening. Can hear it from 20-70mph.
Noise seems to be captured and amplified by my helmet. As described, its less apparent if I take the helmet off (which I don't do normally). I also have Anakee IIIs. Even with ear plugs the noise still resonates within my helmet.
Did you ever figure out the source of this, is there a fix?
I'm going to try a new TKC70 tire on the front just to see if this is an Anakee issue. I don't expect that will help since the current noise doesn't change with lean angle. Also planning to take a test ride with a different helmet, i.e. Schuberth C3Pro.
Thanks,
John
I have 2019 R1250GS with same noise problem. I donít think it is a helmut issue. Iíve changed windscreen already and that helped a bit. Was wondering if the tire change you mentioned helped with the noise?
Colo1250GSrider is offline
post #16 of 17 (permalink) Old 19-May-2019, 01:07 PM (755)
'05 R 1200 Gs
Southpaw's Avatar
I have learned to accept noise. These bikes make noise. They are not cruise queens. My Reemus pops ( cool ). The wind off the windshield wooshes. The tires rumble. The gears are a bit noisy. It is a sensory experience that makes me feel like I am riding a rugged machine and I find it part of the charm.
'05 1200 GS
Southpaw is offline
post #17 of 17 (permalink) Old 31-May-2019, 05:43 AM (446)
Update: mine is R1250GS HP. It came with Metzeler Karoo 3 tires. Front noise so loud I could barely hear the engine/exhaust! Iíve changed the windscreen to Ztechnik mid-size touring, 19 ĹĒ top to bottom as measured in the center, with stabilizers (just get them) which solved the air buffeting completely.
Yesterday, at only 1200 miles I switched tires to Mitas E07 +. This is a 50/50 tire that Iíve used before on my G310GS and loved it. It is actually made for large adventure bikes. I am happy to report the tire change has completely solved my front noise problem! I can still hear a little but 95% LESS noise works for me. It still is decent on the road, and now it is awesome on dirt!
PS: everyone should still wear earplugs - ATGATT !
I am now 100% satisfied with this bike!
Message me if you want to know what else I have added to the bike.
