Strange R1250GS engine noise. - Page 4 - BMW R1200GS Forum : R1200 GS Forums
 25Likes
post #31 of 151 (permalink) Old 30-Apr-2019, 09:25 AM (601) Thread Starter
Originally Posted by Slijkmoto View Post
You're certainly not the only one with this complaint: I am collecting now several similar declarations from new owners of a GS 1250 and most members of the GS blogs I visit, do complain about the irritating noise... However, as my French dealer puts it :"most of his clients don't hear any abnormal noises at all, especially so when upscaling from an oil/air cooled GS, when they are of the opinion that "all" mechanical noises are typical for the watercooled engine... ".
Every time I do collect a new snippet of information reg. this problem I send it to my Belgian dealer who transmits it immediately to BMW in Berlin.
The more complaints are registered, the sooner some reaction may be expected from the manufacturer (who is known to only come into action when it's no more avoidable).
Has BMW come to any conclusion as to the cause of the strange noise.
Took my 1250 to my dealer today. They acknowledged that it didn't sound right and are going to speak to BMW
Maturerider is offline
post #32 of 151 (permalink) Old 30-Apr-2019, 06:16 PM (969)
jaxon's Avatar
Every BMW I've owned makes a weird agricultural sound.
F800GT: Rattling grinding sound.
R1200RT: Sewing machine
K75S: Weird George Jettson whine.
R1200GS: Rattlely
G650GS: Clack Clack
Everyone says "It's normal."
I think these engines are designed to only really have enough metal to handle the load on the component and that finely tuned machining just contributes to each bikes characteristic sound.
fdbm17 likes this.
2017 R1200GS
1992 K75S
2013 G650GS
jaxon is offline
post #33 of 151 (permalink) Old 01-May-2019, 01:29 AM (270) Thread Starter
Any engine that make a different mechanical noise when under load is cause for concern.
post #34 of 151 (permalink) Old 01-May-2019, 05:03 AM (419)
Crucian's Avatar
Noise vs MTBF
Mean time between failures (MTBF) is the predicted elapsed time between inherent failures of a mechanical or electronic system, during normal system operation. MTBF can be calculated as the arithmetic mean (average) time between failures of a system. The term is used for repairable systems, while mean time to failure (MTTF) denotes the expected time to failure for a non-repairable system.[1]
The definition of MTBF depends on the definition of what is considered a failure. For complex, repairable systems, failures are considered to be those out of design conditions which place the system out of service and into a state for repair. Failures which occur that can be left or maintained in an unrepaired condition, and do not place the system out of service, are not considered failures under this definition.[2] In addition, units that are taken down for routine scheduled maintenance or inventory control are not considered within the definition of failure.[3] The higher the MTBF, the longer a system is likely to work before failing. (Thanks Wikipedia)
Are historic engine "noises" on boxer engines an indication of decreased mean time between failure? Is noise associated with the new 1250 series engines an indication of this?
I don't have hard numbers on boxer MTBF but one generally accepted evaluation of BMW engines is that if properly serviced and maintained, they run for a very long time. Many of the nits associated with BMW motorcycles originate with problems with switches and software. No one, to my knowledge, faults boxers for engine case/crankshaft/connecting rod/piston/cam/valve/head issues. Problems with drive shaft/alternator and clutches for instance get some bad press but generally a well maintained BMW motorcycle is good to go.
PoppyGreg and Houdini like this.
Crucian is offline
post #35 of 151 (permalink) Old 01-May-2019, 09:16 AM (594) Thread Starter
Talking
I think what you are saying is 'your bike is doomed'. Fair enough! Nothing lasts forever.
post #36 of 151 (permalink) Old 01-May-2019, 03:03 PM (836)
Crucian's Avatar
Of course, everything doomed at some point. What I am saying is that the boxer Berlin is a seriously dependable internal combustion engine. Kubota 3 cylinder Diesel engines are the preferred driver for refrigerated shipping containers and their MTBF is 16,000 hours. To translate into miles, that's 480,000 at 30mph. (Not truly a good comparison. They run 24/7 and temperature deltas are tough on engines)
A motorcycle engine that sees good maintenance that is capable of 100,000 miles and more is one to respect.
I accept and respect that you and others that have chimed not appreciating the sound of the 1250. If it is sufficiently annoying, get rid of it and go for an inline engine. Just please don't suggest that the 1200/1250 or BMW engines in the past are ready to blow due to mechanical engine noise. Personally I hope your pleasure at the positive operation experienced flying your bike will over ride any audio issues.
Crucian is offline
post #37 of 151 (permalink) Old 02-May-2019, 12:32 AM (230) Thread Starter
My issue is that this is my fourth BMW and this is the first that makes an unpleasant and unexpected mechanical engine noise that I can hear on the move whilst wearing a full face helmet and silicon ear plugs. If this is a characteristic feature of the 1250 so be it. I could live with it because the rest of the bike is so good BUT if it gets worse (I notice it more than I did) a think it would be best if it was sorted sooner than later. I'm no mechanical engineer but I have always thought that sometimes a small noise in time, if ignored, can develop into something major and even catastrophic. Not that I think that will happen in this instance but WHAT IS CAUSING THIS BLOODY NOISE?
post #38 of 151 (permalink) Old 05-May-2019, 12:56 PM (747)
I concur
I have had an oil cooled R1150GS from new (1999) and have ridden a few 1200s for short periods.
A month or so ago I test rode a R1250GS Adventure Rallye and the engine noise was immediately apparent from quite low speeds.
No such noise from the 1150 or 1200s.
It reminded me of worn out cam chain noise from my old (1973) Mini 'A' series engine.
The dealer said that someone else had commented.
We wondered whether it might be tyres as the Rallye has more trail type tyres than my 1150 and I did manage to convince myself at one point that it changed a bit with road surface.
I wondered whether the screen may be somehow reflecting the noise back to the rider.
Today I rode a friends R1250GS with road tyres and the noise was exactly the same as the Rallye
It only becomes unnoticeable over 70 with earplugs in and the visor closed.
I couldn't live with it.
R1150 is offline
post #39 of 151 (permalink) Old 05-May-2019, 03:57 PM (873)
Egnie Noise
I have a R1250 and don't notice and unusual engine noises: surprise:
I think the whole bike is buttery smooth, the only thing I would say regarding noise is the exhaust seems kinda loud but I ride a Goldwing too that is super quiet so my perspective may be different.
Gl1800abs is offline
post #40 of 151 (permalink) Old 06-May-2019, 10:03 AM (627) Thread Starter
Surprise? Oh yes! I did over 80,000 miles on three previous 1200 GSs (one oil head and two LCs) and they never made this noise.
It is just conceivable that mine has a mechanical fault.
Strange Headlight Problem (low beam) ca1ic0cat General chatter 7 01-Apr-2019 02:09 PM (798)
2015 GSA LC Strange Ticks/noise (Clutch) translate Maintenance and Modifications 4 22-May-2016 05:38 AM (443)
Strange bump RandyGarner General chatter 15 04-Oct-2015 06:55 PM (997)
Idel rough strange attitude. Valken Maintenance and Modifications 5 11-Nov-2011 03:44 AM (405)
Strange leak ??? FREDO_RIDER General chatter 5 18-Nov-2007 06:54 PM (037)
