Bar Risers - Page 2 - BMW R1200GS Forum : R1200 GS Forums
 7Likes
post #11 of 18 (permalink) Old 05-May-2019, 03:53 PM (870)
Risers
Wunderlich bar 40 mm risers, they are fantastic. I had the Rox risers on my super tenere but the Wunderlich bar risers are better. I'm 5'9" with long arms.
Luke Warmwater likes this.
Gl1800abs is offline
post #12 of 18 (permalink) Old 06-May-2019, 08:17 AM (553)
Crucian's Avatar
Day late and a dollar short....
I experienced shoulder pinch on long hauls so I rotated the stock bar setup about one witness mark down, (or up) I can't recall. The change in elevation/angle at the bar ends was an inch or so and completely solved my problem. I'm 6'-0" and around 200 but I think there are too many variables to physique to expect identical results.
Rick92040 likes this.
Crucian is offline
post #13 of 18 (permalink) Old 06-May-2019, 07:07 PM (005)
Gdoss's Avatar
Tried both TT’s 2.5 & 4.0 cm. Even with the Rallye high seat found the 4.0 a tad too high when seated. If I were to spend a lot of time on the dirt standing, the 4’s would be my choice but the 2.5’s with bars rolled slightly up are a good compromise for me at 6’3” 33” in seam.
Gdoss is offline
post #14 of 18 (permalink) Old 08-May-2019, 03:33 PM (856)
Originally Posted by Luke Warmwater View Post
Feeling a little shoulder and neck pain during long rides. Would prefer to sit a little more upright when riding.
I am six feet tall, 200 lbs. I ride a 2018 R1200GS, standard height with a standard seat and stock foot pegs.
I am leaning towards the Wunderlich bar risers:
Ergo Handlebar Risers (#41970011-111) Oil and Water Cooled (1994 to present) 41970011-111 | BMW Wunderlich America
as I like their quality, fit and finish. Was searching this topic on the forum and noted that several riders purchased the ROX bar risers. They offer fixed risers and pivoting risers.
The Wunderlich risers come in two sizes. Neither require modifications to the cables, except some minor re-routing.
They have a 25mm size which raises the bars up and back one inch. They also have the 40mm size which raises the bars 1.6 inches.
My question is directed to riders that are roughly my height and riding a GS with a similar setup to mine. Which is better? The 25mm or the 40mm for comfort?
For those recommending the ROX risers, please specify height of risers and whether you bought the fixed or pivoting type.
Not really interested in lowering foot pegs or changing seats at this point. Want to give the bar risers a try first.
I have similar Wunderlich risers on my '08, on which I needed higher bars for standing. I prefer them, in my application, to the original swiveling Rox because they are less fiddly to set up.
BUT, they may not help you much. If you take your hands off the grips and raise them up 25mm, you'll see that it doesn't change the position of your torso much. To sit straighter, you need to move the bars back as well as up. (The risers you mention do move back, but only because of the angle of the steering crown.)
These might be better: https://www.advdesigns.com/rox11barifor.html
TedC is offline
post #15 of 18 (permalink) Old 09-May-2019, 03:58 PM (874)
Not that senior.
gdayjr's Avatar
Bar Backs
I am 193 cm tall. or 6ft 4, and i fitted a set of "bar backs" on my 2010, and i have moved them from three previous bike they are so comfortable.
https://www.amazon.com/SW-MOTECH-Bar.../dp/B00V507CD2
Graham Day. Sydney Australia
2004 R1200GS. 88, 000 km
2007 R1200GS. 34000 km.
current bike. 2010 R1200GS. 83000 km and going as good as new.
gdayjr is offline
post #16 of 18 (permalink) Old 09-May-2019, 06:48 PM (992)
Im m5'11 and 140Lbs, with 31 inches from my arm pit to the tip of my fingers, and use the ROX risers that are adjustable back. When I set the cruise I'm able to sit straight up and keep 3 fingers on the right grip...Its not my 2006 1800 Goldwing but then again I knew it wouldn't be. Around town I lean in slightly.
JMB711 is offline
post #17 of 18 (permalink) Old 11-May-2019, 01:29 PM (770)
I'm 6'3" and have 25mm risers, and I can't imagine the bike without them. The posture is just right.
charles is offline
post #18 of 18 (permalink) Old 11-May-2019, 08:53 PM (079)
Senile Member on 2006 GS
6'1" with a 34" inseam. On my '06 GS, I run the seat in the high front/low rear position (that the manual pretty much tells you not to do), and have a set of ROX B17R-15M non-adjustable risers that move the bars up and back 1.5 inches. This combination works pretty well above the waist, though I still feel my legs are a bit cramped. Last year, I also ran a Seat Concepts "tall/GSA" foam/cover kit, which gave me better legroom but had me reaching too far forward (like stock seat and bars without risers), plus it got me just high enough to experience all kinds of shoulder and helmet buffeting. So, back to the terrible stock seat for now, and I guess if I want more legroom I'll look into lower footpegs. Anyway, I like the ROX risers a lot. They clear my tank bag (an old Buell item that I think was made by Wolfman) and provide the added bonus of just enough clearance in front that I can clamp a water bottle holder to the handlebar without blocking my view of the speedometer.
saughblade is offline
Bar risers & adjustable footpegs tommarbru Accessories 4 11-Jul-2015 03:37 PM (859)
Rox risers vs ilium works risers for 2013 r1200gs LC Jeffreytucker Accessories 2 13-Oct-2014 01:46 PM (782)
Wunderlich Bar Risers ascensius Maintenance and Modifications 5 04-Oct-2014 09:52 AM (620)
Bar Risers for new 2008 R12GS [email protected] General chatter 7 18-Feb-2011 08:11 AM (591)
