Balancing the Wheels - Page 2 - BMW R1200GS Forum : R1200 GS Forums
 12Likes
post #11 of 17 (permalink) Old 09-Sep-2019, 07:30 AM (520)
Always balance the front and rarely need to balance the rear.
merlot likes this.
Also Ran is offline
post #12 of 17 (permalink) Old 09-Sep-2019, 09:57 AM (623)
Originally Posted by Pterodactyl View Post
You missed my point.... I suggested balancing the wheel if the wheel tire combination is not going to be balanced. No chance of two sets of weights.
There is chance of two sets of weights if you balance the wheel then install the tire and do not recheck the balance of the now assembled components.
PerazziMx14 is offline
post #13 of 17 (permalink) Old 09-Sep-2019, 11:45 AM (697)
Survivor
Pterodactyl's Avatar
Your logic is tough to follow there PerazziMx14. So, I have a wheel and the wheel has weights on it to put in balance. I add a tire to the wheel and I do not attempt to balance the wheel tire combination, therefore I do not add weights to the weights already on the wheel..... yet somehow I have two sets of weights.
60Aviator likes this.
Kevin
The Outpost, Silver City, Montana
Team Pterodactyl
2018 Ural Gear Up, 2017 R1200GSA
Pterodactyl is offline
post #14 of 17 (permalink) Old 09-Sep-2019, 05:08 PM (922)
Doing it that way is no different than just installing the tire and riding off into the sunset. Balancing the wheel and then adding an unbalanced tires to the wheel would translate to an unbalance wheel tire combo?
post #15 of 17 (permalink) Old 10-Sep-2019, 02:23 AM (307) Thread Starter
merlot's Avatar
i think im going to be ok
the front is balanced
the rear is not,but the weights already on the rear,are opposite the TPS
this makes sense to me
unfort i cant ride the bike yet,as the exhaust is getting ceramic coat,and the guy is still waiting for product he ordered
when i balanced the front,i only needed to move the balance weight previously fitted,a small amount.the weight ended up opposite the TPS...i prob would have got away with not balancing the front
i dont thing 110KPH is going to worry these tyres re imbalance
thats a great idea to balance the wheel....then im only looking at the tyre out of balance,and these days the tyres are fairly true(decent brand names)
the next time i change the tyre thats what ill do
thanks for all replies
russ
Rick92040 likes this.
2013 LC
merlot is offline
post #16 of 17 (permalink) Old 10-Sep-2019, 02:43 AM (321)
Abba makes a bush to fit. Google Abba rear wheel adaptor 1200gs
with tps mine always needs to be balanced opposite the tps. manual says max 80g and it always needs 80g to get towards balance. i prefer to do it but many places don't bother
merlot likes this.
JohnJo is offline
post #17 of 17 (permalink) Old 11-Sep-2019, 06:55 AM (496)
I change my own tires and started using balance beads many changes ago. Initially I used beads designed for the task, but have recently changed to using airsoft beads. They are hard rubber and Iíve reused them over multiple tire changes because there were no damaged beads and no obvious change to the inside of the tire. I make sure to use 2 oz of beads and bothfront and rear are quite smooth at 100 mph.
merlot likes this.
Bill
2014 R1200GSA
Lucecannon is offline
