Yes it does exactly that.So what does the auto mode do? Does it change preload on the fly?
That was one of my questions where I did not receive a response (on another thread). When in Auto mode, is the suspension set to its lowest height when at a stop?
Hi Lamby66,Has anyone looked to see if the factory linkage plastic cups are threaded to allow adjustment? If what the OP stated is true where a 3mm adjustment results in a 25mm ride height change, maybe shortening the threaded (if it is in fact threaded) rod 3 or 4 mm and threading the rod a little further down would allow the adjustment range needed.
Given that it only adjusts ride height at a stop, it's not what I would call "on the fly" adjustments but I assume more of an automatic adjustment at bike start-up for changes in [rider + passenger + luggage] total loaded weight to bring the bike back to an OEM selected ride height. But in the way BMW describe it, ESA also makes adjustments to damping and, seemingly magically also "spring rate" (See the detail here:
ESA & ESA II - technology in detail).
In any case, if one jiggers the sensor via this device, seems it might well be affecting more than just the ride height when damping changes are also involved. ie. maybe the sensor is affecting both spring pre-load and damping characteristics. In this case, it may have unintended and unpredictable consequences when the bike is put into more "dynamic" scenarios. .... I'd be a little leery of making this mod without a lot more info as to how the ESA programming works.
well to quote myself for others that might want to know....Has anyone looked to see if the factory linkage plastic cups are threaded to allow adjustment? If what the OP stated is true where a 3mm adjustment results in a 25mm ride height change, maybe shortening the threaded (if it is in fact threaded) rod 3 or 4 mm and threading the rod a little further down would allow the adjustment range needed.
Hi virkdoc,Ok so my friend did the mod. We took measurement in Auto Max and Min
He took 2 points on the bike and in Auto the bike stood at 570mm at Max it stood at 590mm and at minimum it stood at 550mm.
He put in the rod.....which was 3 mm shortwe as the OP had suggested.
The bike dropped to 552ish mm in auto. The maximum and minimum stay the same. 550 and 590. That is the range of motion of the shock and that doesnt change even with shortening the linkage.
Lets see how it goes over the next few days....will load her up and take some more measurements.
This mod only changes where the bike thinks it is during it's auto leveling preloading. It allows us to adjust the bike to have the preload (ride height) we want,not what BMW coded. This SHOULD be allowed electronically but this work around works wellHi, I know i have only owned a BMW for 5 minutes but i’m a little sceptical as lowering the suspension hight can be done as easy as just changing the length of a rod at the cost of £16…… so why do BMW charge 1000’s
i‘m always open new ideas.
Great discovery and discussion. I am assuming since this mod reportedly LOWERS height in Auto and does not affect Min or Max, no variation of this mod could INCREASE height. Correct ?Many people would like a GS but shy away because of the size or height of the bike hopefully the following may help.
I own a 1250GS with lowered suspension/chassis, which of the 3 settings available high, auto, and minimum I ride in minimum mode all the time because I am 5’7” with an 28” inside leg.
This is OK until the bike is loaded with panniers and a passenger, it then sinks (sags?) much lower to the point that in full touring mode it is way too low. The ideal solution would be to use auto mode thus compensating for the extra weight but in that configuration it is too high to be comfortable/safe especially when fully loaded.
I noticed the height sensor link rod at the rear and though that adjusting it length may provide a solution. A quick search on eBay came up with a few possibilities. I settled on the one in the picture, it is designed to be use as an adjustable headlight levelling link rod for cars but happens to not only have the required length range but all the threads were the same as the original link rod.
The photo’s are self explanatory but if you do this be careful! to lower my bike 25mm (just over an inch) only took about 3mm of adjustment shorter than the original link rod.
I now leave the bike permanently in auto mode and the ride height is now comfortable for me regardless of load.
I hope this may be of help to anybody with a similar problem but the usual applies, you do this entirely at your own risk and I accept no responsibility whatsoever for any problems , damage, injuries etcetera that may occur as a result.
Stay safe.
View attachment 32394 View attachment 32395 View attachment 32396
Correct...the minimum and maximum limits are set. The shock will not move out of that rangeGreat discovery and discussion. I am assuming since this mod reportedly LOWERS height in Auto and does not affect Min or Max, no variation of this mod could INCREASE height. Correct ?
That will be just the rod with no adjustment. The advantage of the threaded rod is we can actually play with different height settings.I know the parts will be more expensive, but what about getting a rod from a standard GS or a factory lowered GS as it will look more OEM than a generic threaded bolt
