I recently purchased a 2005 r1200gs, on doing a service and check was unable to remove the drain plug from the final drive assembly the threads in the casing have been stripped by someone so ill have to remove the assembly and drain from the speedo sensor hole, just wondering if anyone knows of how much oil i should pop back in once drained overnight thanks in advance.
