1 - 8 of 8 Posts
Am in the process of outfitting my (new-to-me) 2008 1200GS. I rely on my mechanic for most things, but I’d like to figure out how to hook into the power of the bike for a USB charger and possibly putting power in the Vario top bag. How do I do this? What do I need in terms of cables and accessories??? Does it all have to come from a cable connected to the battery terminals? I remember when I bought the bike they looked around for the power socket, pointed it out, but I had other things on my mind (like getting used to handling the bike) when I started to ride it. I have yet to find a good diagram of how to hook up this particular year model.
There’s soooo much info out there it’s hard to wade through it all. I’m looking for something simple. A pre-wired tank bag from RKA looks like a good addition, but where do I plug it in?
I have a battery tender extension…
Thanks in advance !
2015 R 1200 GS
That would be the easiest way to connect a SAE-USB adapter .
Another way to consider if you have more accessories to come is to add something like Denali power distributor. this will connect directly to the battery and it will allow you to connect each accessory to a separate fuse inside the box .
2015 R 1200 GS
Here is the one I meant
FZ-1 Fuseblocks are nice. 6 fused power sources built in 30 amp relay and can be wired for triggered power. $89 is easy money for what you get. Also very compact. Fits nicely under the seat.
Discussion Starter · #5 ·
Thank you! $89 sounds a lot better than $150 for Denali, but I imagine like everything, you get what you pay for. I’ll check it out.
Discussion Starter · #6 ·
Thanks! I’ll check it out.
I have converted my Touratech tank bag (the brand did not matter, that could be done on any soft or hard luggage) to have some internal 12 V.
30630
I have a DIN plug fuse-wired to the battery (I wanted my bag to be powered all the time(
Inside, there is a 2 outlet USB charger
30631
When I don't use the tank bag, the bike-side plug sleep peacefully in the bag attaching point.
30632
And connect like this, I left enough slack to flip the bag forward to fill with gas.
30633
1 - 8 of 8 Posts
