1 - 4 of 4 Posts
Need some advice as my instrument cluster is totally dead no display on LCD Mileage etc. - bike starts drives well indictators brakes etc working except for the hooter is also not working any advice could this be a ZFE issue perhaps or could it be the kombi itself 馃榾
Below just a sample of a similar cluster - mine is totally dead
27678
New battery fitted as well ...
"There is no physical fuse. The ZFE monitors current use by the accessory socket and turns the socket off -- blowing a virtual fuse -- when the current is too high. Next time you start the bike you will again have current to the socket. It's even possible that after some amount of time the ZFE will test the current use by the socket by enabling it on its own.. not sure about that. "
Info from forum quoted ...
If you have a local BMW club they may have someone with a GS911 to see if there are codes to help diagnose further.
1 - 4 of 4 Posts
