1 - 8 of 8 Posts
Hey Guys,
quick question: where is the battery located on a 2015 ? Under the tank or under the seat ? I am picking up the bike Saturday morning and need to install a powerplug for my heated gear. TIA
Behind a panel on the right side under the seat.
Here is a link so you can download the user manual and it describes everything you need to know BMW Motorrad : Service : Manuals
I found my manual to be lacking everything! they dont even show what needs to be changed at MILE 600 for the first service they just say BREAK IN SERVICE.
But the battery is where you mentioned, i just install a power plug on my bike
Guess I have a pretty good dealer...he installs a power lead on the battery of every new street bike he sells...standard procedure .
When put one on, don't pull the battery because there's no need. Just use the exposed negative (earth) terminal and then there is a jumper positive terminal next to the battery. Just connect the positive lead to that, it makes things simpler.
1 - 8 of 8 Posts
