Need the part numbers for the Brass Insert and screw located at the lower end of the fuel tank. I cross-threaded the screw and it was impossible to untighten as the fitting was also spinning with the screw, so I had to carefully remove the brass fitting (see pictures). I think the screw is M5X14,5-A2-70 but not 100%. Any help is greatly appreciated!
