1 - 19 of 19 Posts
Ok so I want to install these lights so that they run at 50% when riding and go to 100% when I honk the horn. And so I can make them go to 100% when I want to. I’m told that with what I have it can be done. I know I could pay someone to do that but would love to do it myself.
Any help?
Brick
'14 R1200 GS Adv "Freya"
Connect EZCAN to your computer and start the configuration drill.
You will have to choose Light Brightness for both Day and Night, low beam and High Beam.
The EZCAN setup menu gives you an option to select the Horn Flash of the lights as well as the random flash routine if you double flash your passing lights.
There are many YouTube clips that will step you through all the configurations that you mentioned.
Once you connect your laptop and open the app a lot of things will become clearer. Its mostly self explanatory. Also at every setting there is a help feature which explains exactly what that feature does.
You will enjoy it @Brick. Its just very cool fiddling around with all that.
Ok so I want to install these lights so that they run at 50% when riding and go to 100% when I honk the horn. And so I can make them go to 100% when I want to. I’m told that with what I have it can be done. I know I could pay someone to do that but would love to do it myself. Any help? Brick Sent from my iPhone using Tapatalk
What BD lights are you installing ? You can dim the 2-wire Baja Design lights, but the dimming is not proportional to the slider on the ezCAN vs votage. I have found I can run my S2's down to about 6V before they shut off. The Squadron Pro's I can run down to about 8V before they shut off.
I successful installed the Baja spot lights on my 2020 R1250GS. The lights are a two wire so I can’t vary the brightness with the wonder wheel. And when I turn on a turn signal, instead of that side Baja light going out... in my instance both go out during turn signals operation. I’m completely satisfied. Thanks y’all!
Beick
Beick
Beick so whats happening is:
1) You have put two Bajas on the same circuit instead of left and right (Using 2 circuits)
2) Brightness can still be varied......push your wonderwheel to the left and hold for a few seconds......they will flash and then you can increase or decrease the output.
My earlier Hellas were also 2 wires and i could vary intensity even with the older Hex EZ Can I had.
Virkdoc,
Hmmm... I have both of the Baja lights on the same circuit via a “Y” cable to a single two wire EZCan circuit. The instructions didn’t say anything about using the Wonder Wheel the way you said. I will try that today. If I triple flash my Flash to Pass lever the Baja’s go into a strobe for a few cycles.
Thanks for the information. I’ll reply back if it works or not.
Brick
Discussion Starter #9
Virkdoc,
Brick
Virkdoc,
Well that is not exactly how mine works. A friend who had a two wire light system on a 2018 GS showed my that with the bike running I hold in the turn signal cancel button then turn the Wonder wheel I can vary the brightness.
More to learn.
Now I’m trying to hook up my AdMore brake/tail/turn signal light.
Brick
Virkdoc,
More to learn.
Brick
Brick what bike do you have?
Oh shucks lol....so the trick with the turn signal is for bikes which do not have the wonder wheel.... did you try holding it for 8-10 seconds to either left or right....try both.....
Discussion Starter #13
You said try holding “it”... is it the Wonder Wheel??
Ok so Brick the wonderwheel can move left or right....so hold it to the left first for 8-10 seconds....ur lights will flash.....once they do then rotate it to increase or decrease the intensity......
I think it was hold to left.....if it doesnt work hold to right
Im 100000% sure on this......park ur bike facing the wall or garage door so you can see the lights flash
Discussion Starter #15
Ok so I did as you said... left until the lights flashed. Then turn the wonder Wheel. It’s very “clunky” and non-linear in action but it does sort of vary the brightness. For instance I was turning them brighter... it took several almost full turns. Then I tried turning them back... I had to hold the wheel to the left until a flash then I could turn them down again several almost full turns.
I once again tried the turn signal cancel and instead of flashing the lights go off. To get them on the same ... hold the turn signal cancel button down and they come back on.
More functions than I thought would be possible.
Brick.
Discussion Starter #17
Yes I bought it from Eurosport Asheville when I bought the bike on 6/6/202.
Perfect so your lights can be switched off by:
1) Press the turn signal 3 times quickly
2) Long press the turn signal for 3 seconds
1 - 19 of 19 Posts
