1 - 3 of 3 Posts
I'm new to BMW motorcycles after four decades on English and, well, Brand X bikes. Just purchased an R1150GS of 2004 vintage. When "parking-lot riding" to get the feel, after a self-induced panic stop, the ABS system seems to simply die, meaning there are no flashing lights and the RID does not indicate the system is even on. After shutting off the ignition and restarting, the system comes back alive, i.e, the red ABS light flashes until going faster than 3 MPH and the pump whines a little, etc. Are we allowed only one panic stop per riding event? I've searched this site for applicable service bulletins but have seen nothing except for 2005 or later R1200GS bikes. Speaking of electrics, is there a simple code reader which can be used to read the fault codes in the motronic (as there is for BMW cars) or must a dealer do that? Many thanks for the assistance. Shineman
If I understand your question correctly, the system is behaving properly.
I have an '06 GS. The starting procedure for mine is as follows:
Turn on ignition.
Computer goes through self check, with red, then yellow indicators turning on, then off. Brake failure message blinks in red.
Start engine.
Brake failure light continues to blink.
Place in gear and begin moving.
Brake failure light blinks until you reach about 3mph, then light goes out. ABS is now enabled.
There are no indicators after startup that ABS has been enabled, however, if it fails you'll get the brake failure light. You also get it (for awhile) if you disable ABS using the appropriate button for off-pavement riding. Also, if you are holding either some front or rear brake during the start sequence, you'll get the brake failure light. I find this somewhat annoying when trying to start on a hill!
Kool Aide Dispenser
Like above, there is no indication of it being on once it sets itself at 3mph other than a servo whine and good brakes.
IF there is an issue the ABS light will come back on and flash at you.
If you want to test it, go back to the parking lot and do a 20mph brake test using ONLY the rear brake. You will feel the ABS kick into action. You can do this repeatedly.
The advantage to the servo-ABS system is that the servos allow very fast refresh time on the ABS unit, making it much smoother than non-servo ABS units prior to 2007 BMWs.
When activating the ABS in this manner, or any other, you will get no other indication that it is on, but it will work repeatedly without restarting the bike.
Jim :cool:
1 - 3 of 3 Posts
