1 - 4 of 4 Posts
2016 R1200gs. How do you adjust preload for 2-up plus gear on a bike with dynamic ESA? Manual only provides direction for a bike without dynamic ESA.
Left handlebar switch with a spring made on it.....keep it pressed...it will toggle between one helmet and 2 helmets etc
What if it’s not enough? No other way to adjust to hit 65mm 2-up with hear?
Then its time for custom shocks....Wilbur's, etc. There is a "local" suspension shop in Asheville that makes to your spec. I'm sure there are shops all over the country.
1 - 4 of 4 Posts
