1 - 5 of 5 Posts
welcome bmw r18 owners
for the BMW R18, we started designing side brackets for the side bags amd saddlebags
29373
brackets construction
29374
scan BMW R18 motorcycle
29375
reverse file
29376
29377
Cut metal plate with Laser
29378
INOX Stainless steel pins for easy remove
29379
powder black painting
29380
you can now mount many different shapes of saddlebags ... from ABS, Plastic, Fiberglass, Leather ..etc
29381
a2 x metal plate with holes has been added for easier attachment, especially leather saddlebags , install metal plate from the inside - to make them more fixed
29382
the brackets ready for BMW R18 will be available in April .. 04/2021,
and
the suitcases ready for BMW R18 will be ready in May .. 05/2021
regards, for all helps ,Oldtimers TEAM
Discussion Starter · #2 ·
Fasten the saddle bags from the inside to the lower bracket easily with the supplied M6 screw, close the saddle bags and lock them with a lock.
so it is completely attached and safe to use
29383
29384
Discussion Starter · #5 ·
hi guys
we make a beautiful ride with R18 and new saddle bags
its easy to fix or remove
regards,Mec
1 - 5 of 5 Posts
