Hello im new to forum and have a major problem with a non running bike I bought. the bike spins over but won't start (ews) displayed , I have replaced the battery and the antenna with new parts , bought a obdlink mx and motoscan ultimate app to read the codes , buzzed out the antenna 4 wires back to the ecu and seems fine? I wonder if someone has an old bmsk (ecu) that I could try and see if the app read the immobiliser section? if it does then the fault maybe in the old ecu , it also checks out the wiring? im stuck with this problem........ANY HELP PLEASE
do you know a good mechanic/tech in the area that can help , thank you
