1 - 20 of 21 Posts
R1250GS 2021
After few screens and modifications, I've finally reached what I wanted. Now I have zero buffeting.
When I took delivery of my new bike back in January this year, the buffeting was horrible, just after 80 km/h. Tried BMW Adventure screen, a bit better but nothing special. Purchased Puig Adventure screen and it got better but buffeting was still there at 100 km/h. I'm 6'2,5 with 34 inseam.
Then purchased spoiler from Puig, drilled the screen and installed it. It got better. Wind noise was dramatically reduced and buffeting was better but I couldn't ride the bike over 120 km/h because of a headshake. I thought I couldn't do anything else as Givi doesn't manufacture Givi Airflow for my bike and that is the only screen I used on my previous bikes that removed buffeting 100%. Then I remembered to install some spacers on lower screws to tilt the screen towards me as much as possible. It got better. Now buffeting was starting at 130 km/h and the bike was rideable over that speed because the headshake was not that strong. Then I purchased some lexan and brackets and made custom wind flaps, something like a wind flaps on GSA models. Took long time to fabricate them and at the end they made no difference.
After that I gave up as I didn't want to spend more money trying to get it better. Just one week ago I decided to make one last attempt. I purchased Givi 5124DT and wanted to attach upper portion and sliding brackets of Givi Airflow. I thought it was worth a try. The screen arrived today but the upper portion and brackets I left to order later as I wanted to test the screen alone first.
I compared the shape with Puig and it looked the same to me. The bents on the screen are a bit different but all the rest was the same. I thought it would give the same effect as Puig without spoiler. When I mounted it I noticed it was much lower then Puig, which surprised me as the size, shape and holes positions were the same. Then I noticed that it looked lower because it was tilded towards me much more then Puig. However, I mounted it using the same lower spacers I had with Puig.
Went for a ride and boom... no buffeting at all. What a surprise. Tried few hights of the screen and noticed it gave zero buffeting only completely down or completely up. Any position in between, the buffeting started. The reason is that the screen at fully up and fully down position is tilted some more towards a rider. In between it tits forward and that is enough for the buffeting to start. Ridden up to 180 km/h and really, no buffeting at all.
This screen and the setup I use is a bit more noisier then Puig but I don't care about wind noise because I use ear plugs.
Here are a photos of my setup.
Life is good now...
29732
Professional Nomad
On the topic of wind protection, there are two separate issues: windblast and buffeting.
On many adventure bikes, the distance from the screen to your helmet is so far that by the time the air gets to you, a lot of eddying and buffeting has built up. The only way to combat this buffeting is to keep increasing the screen size to compensate for this distance until you finally get a large bubble of still air between the screen and helmet. 0 buffeting and 0 windblast. Problem solved.
But then you're stuck with a screen the size of a barn door.
What many people don't realize is that buffeting is the real enemy, not windblast. A constant flow of clean air is actually not that fatiguing and on a forward-canted seating position, like a sportbike, the airflow can actually help to keep the rider up and off their wrists.
I went to a shortie screen to prevent buffeting. Done many 500+ mile days with this setup and haven't felt fatigued at the end of the riding day. And the bike looks a lot better than a Harley-type barn door bolted to the front.
Only downside is that you might be cleaning the bugs off your visor more often. Also a good set of earplugs help.
My research includes 15+ years of riding this (Aeroflow - largest windscreen you can buy on the market):
To finally figuring out this was the optimal solution (sexy, small OEM sport-windscreen):
Just large enough that the back of the GPS doesn't get monstered with bug guts...
I agree with lightcycle.
When I buy a new bike with a screen usually the best option is to go lower rather than higher and to compensate for less weather protection I use a good sized tank bag.. After 40 years travelling around Europe on wind blown motorways it works for me.
I agree, that smaller can be better to reduce buffeting...
Is there a GS Rallye screen available in dark tint?
Haven't been able to find one.
This is the part number for the clear rallye windshield
46 63 9 467 786​
WINDSHIELD RALLYE​
Professional Nomad
46 63 9 467 786​
WINDSHIELD RALLYE​
I found a couple. There's an OEM one:
Part number: 77338559548
And also a company called WRS in Europe also offers one. Looks less glossy, and more matte:
R1250GS 2021
Discussion Starter · #6 ·
As I'm considered "tall" rider, I have been always fighting with screens over last 30 years. On last 5 bikes Givi Airflow on low position was always perfect solution. My new R1250GS is my first BMW bike and I started to question if I liked it or not, just because of the buffeting. As I have it solved now, I need to ride it more to really fall in love with it. As I mentioned above, it gives me zero buffeting in full up or in full down position. So, that is good for me as I now have a setup for summer and winter. It is a bit noisy but my plugs attenuate the noise so it's not an issue. Maybe I'm just imagining the noise too much as the test was at very high speed all the time.
I have a lot of work in coming month but after that I will test it at normal speeds.
Thanks Lightcycle!
BMW version shows out of stock so I'll be ordering the WRS.
I don't have one, but a lot of guys like the Slipscreen from MachineArtMoto (same guys who make the rubber X-Head cylinder head guards). It's opaque though, not dark tinted.
In the past I have bought a cheap used oem screen from ebay and gradually reduced the length/height until the buffeting/noise became acceptable. A Dremel multitool or similar is ideal for the job. Once the height is established the edges can be filed and sanded to obtain a god finish, or a better quality aftermarket screen of similar size can be obtained.
I’ve got a Z-technic Slipstream on my ’17 GS and love it, but I’m only 5’-8”. It works well in most positions, but the problem I’m having is that it reflects the engine and front tire noise right back at me and it’s loud.
i guess that means the wind noise is mostly gone.
I solved my buffeting for good as well:
Had some plastic lying around from a kayak project and fabbed these up. Completely stopped the highway wind blast that hit my chest and made my helmet vibrate. The only thing a lower windshield is doing is blocking the updraft which causes the buffeting by forcing more air over and around it. This way I'm stopping the channel of air that causes the buffeting. Very smooth at highway speeds now.
R1250GS 2021
Discussion Starter · #14 ·
The question here is not about "wind noise" or "comfort". It is about buffeting that is something completely different as it will blur your vision on higher speeds and can end up being very dangerous.
I had buffeting problem over 100 km/h but never so bad to blur my vision. However, after half an hour or so I'd feel fatigued and had to stop to rest.
As about wind noise, I don't care as I use good ear plugs to protect my hearing that is not so good after more then 30 years of riding and 20 years without ear plugs.
I have used the Cee Bailey on 4 BMW- RT, LT, GSA x2.
I am 6'4 but only 30" inseam.
I tried Aeroflow. Really good <60mph, then is started waffling badly.
CB I got made TALL... Then I do not raise it much at all- just enough to get some bottom air flow.
The "height" moves the top of the screen much closer to me and hence less space for the air to collapse.
They have been wonderful----till they closed shop. Sad day.
R1250GS 2021
Discussion Starter · #16 ·
I've always had buffeting problems on my previous bikes, starting from the period I got older and gave up on sports or naked bikes. I tried many screens on many bikes but the only answer for me was always Givi Airflow that took away all the buffeting.
My new GS is my first BMW and my bad luck is that Givi doesn't make Airflow for R1250GS and I simply can't understand why. They have it for previous GS models. I still didn't give up on the idea to fabricate my own Givi Airflow out of Givi parts.
I have a buddy that bought a brand new 2019 GS and about 6 weeks later traded it for a new GS "low" becaeu it was too tall. Then tried 7 windscreen then traded the GS low towards a gently used RT then traded it towards a new RT now is waiting on his new K1600 to arrive. Said he cannot stand buffeting. I think he just likes buying motorcycles.
I hate buffeting and with previous fz6 fazer I lost my battle with tall windsreens, buffeting stopped when I finally chopped puig screen and got my head in linear, non-turbulent stream. Then I tested varoius adv motocycles and tall screens made me doubtful about having big bike without headache coming from windscreen. It was until I tested tiger 1200 desert edition with tall screen. I was blown away how wind protection could work, without buffeting or any other unpleasant on my head. Now I have GS 2005 with standard screen and MRA deflector, it's ok, minor buffeting. Without deflector it's 15 min ride and I regret riding that day, it's terrible. I bought second, used, very short screen for summer, already tested it and it's a bit too tall to have helmet in clear stream, it pushesh air to the chin area. I might chop it down an inch, so the screen just cover the speedo, keeping my head cool and without shaking.
I think the thing most people don't realize is that buffeting (for the most part) comes from under the windshield and over the tank and up your chest. Next time you're out going highway speeds put the palm of your hand in front of your chest facing down, then follow that pressure stream to see where it's coming from.
Si, senor! Big solid windshield causes big fat underpressure area behind the screen. This underpressure sucks air from different regions to compensate, causing part of buffeting. Overpressure sliding from the sreens top edge is sucked down, causing serious turbulences. Some windshields have holes to let air into underpressure zone to neutralise it. Deflectors mounted on the top edge of windshield in some distance from the screen, slices high pressure air directing it upwards, but the fact that speedy air is both behind and in front of the deflector, makes it so effective. Less pressure difference makes less turbulences. Each combination of screen and deflector might have sweet spot where it actually works, some will just cause bigger mess than screen alone.
1 - 20 of 21 Posts
