Same issue on the right side of my 2017 R1200GS. Tried all the reinstallation of panels in sequence to no avail. Not a big deal, and not very noticeable fortunately.HI. I have a 2014 GS LC that I bought used. The bike is in great shape and runs well. I have one problem, the center decorative piece that goes around the gas tank fill neck and runs down the entire length of the gas tank will not lay flat on both sides of the gas tank. The rubber fittings under the trim piece are in correctly. I have about a 1/4 inch space on both sides. I have reseated the trim piece 4 times and it always does the same thing. Has anyone seen this before and if you have do you have any idea as to how to correct this problem?
