1 - 2 of 2 Posts
Just wanted to let you know that I did the conversion from the defective fuel strip sensor to the float potentiometer sensor on my (newly acquired) 2008 R1200GSA with electronic suspension (ESA).
I followed the instructions at this UK GS forum: Instructions
One word of warning, the English at this British forum is barely comprehensible to me. As a result, it took all day to complete, but it worked without a problem.
The parts you need are float sensor 16148554065, a OBD Solutions MX+ Bluetooth adapter and OBD port cable adapter and the MotoScan ultimate app.
Remember to remove the old fuel strip sensor, which hooks on to a metal hanger that is suspended from the gas cap inlet area.
Loop the two blue wires from the new float around something, as pictured, so that they won't touch the float, or your reading could be affected.
Also, when you insert the new fuel pump/float assembly, the float will get lodged between the tank and the fuel transfer hose in the tank bottom. You'll need to then use a hook or long screwdriver to pull the float up and free.
You must fully remove the tank to do the work because the ZFE computer wiring harness is under the tank, and you need to swap the pins. The instructions aren't clear, but the connector with the pins to swap is the upper one with the fatter wiring bundle.
To remove the inner wiring pin holders from the ZFE harness, you need to remove the top shell cover. To do this, carefully pry the back and front corners of the cover's flange up with a small screwdriver while sliding the shell forward. Do this successively in both sides until it is free.
I'm not sure if it's necessary to first clear the fuel strip fault with the resistor network pictured below, as is the case with the preobeemer.nl signal converter, but I did it anyway just in case. I doubt it's necessary, however because you are deactivating the fuel strip during programming.
Please ask if there are any questions. I don't recommend doing this work unless you are pretty good with mechanics and electronics, however.
Hand Gesture Finger Gadget Communication Device
Font Schematic Parallel Rectangle Engineering
Electrical wiring Finger Electrical supply Thumb Wire
Automotive tire Automotive design Motor vehicle Electrical wiring Auto part
Finger Electrical wiring Thumb Cable Electronic engineering
Hand White Fluid Gas Machine
Automotive tire Motor vehicle Automotive design Camera Cameras & optics
Hallelujah!!!
Speedometer Odometer Trip computer Light Motor vehicle
Automotive tire Eyewear Audio equipment Font Wood
1 - 2 of 2 Posts
