I just put on a set of the trailmax missions and rode mojave preserve.
All of the reviews call them a 50/50 tire that punches above their weight, don't believe the hype, they are 80/20 or 70/30 at best.
The good: zero noise on the highway, they are comfortable, smooth and handle well changing lanes, dodging potholes and tracking straight. In the rain the front is excellent and sticks to the road, you can feel the rear want to step out but if you ride like you should in the rain, a little extra careful, they wont. These are great on hardpack, dirt, shallow gravel, rocks, off camber, medium soft to hard ground surface. If you're riding fire roads they'll do everything you want.
The bad: In sand you will just dig down and plow, they are not good in sand at all, they do not inspire confidence, and I ride quite a bit in sand living in southern california. Its a very hard tire compound and the sidewalls are super stiff, I've never had so much trouble spooning on new tires, you'll need a heat gun/blowdryer to soften them up and plenty of windex. They respond well to airing down to 26/28psi (no luggage). They aren't as heavy as motoz tires but heavier and harder than more street oriented tires.
The ugly: I haven't taken them in the canyons yet but I'm running a 120 front and 150 rear on an 05 1200GSA with suspension that needs replacing and it wants to understeer. Lean it way over and it runs wide in turns. Once this rain lets up next week I'll take it to ortega highway and see how it handles a few miles of twisties, but its not looking as good as my previous tire set up, kenda big block paver in front, kenda cruiser on the rear. The mitas will be leaps and bounds better off road but the trailmax missions will give you more traction on road.
