1 - 18 of 18 Posts
Yes, and switching traction/ abs on / off
And the suspension thing... So is that All what the user can manipulate?
You can go into setup and play with 2 modes only
Enduro Pro and Dyna Pro
For Dyna Pro from the factory it is set up to:
DTC: Dyna (You can toggle between Road Rain Dyna)
Engine: Dyna (You can toggle between Road Rain Dyna)
Discussion Starter · #5 ·
Thanks.. Dealer informed me that, because I was in motion
My settings tab was disabled, I need to set this up when stopped... Now I know...duh
R1200GS(A) LC bikes, just a point of clarification for late comers reading this post, you can be IN MOTION while switching between modes on the fly, just pull in the clutch and don't apply throttle. Example, if you're riding in ROAD, toggle to DYNA, it will stay there. Pull the clutch lever and release the throttle. Mode changes. I use it mostly going from Enduro to ROAD or DYNA and back again, but it doesn't matter as it works for all modes.
Font Parallel Screenshot Motor vehicle Document
I've hunted through my manual and on my 18 I'm getting the feeling it's not adjustable. "Those" settings are not in my menu at all.
I have an '18 and I can adjust them.
Are you sure you have the under-seat red plug installed? If not your bike in just in regular Dynamic and regular Enduro which are non-adjustable.
Where on your 18 in the menu is the setting?
Downpress on the MENU button.
Four clicks to the right on the WONDERWHEEL over to "Settings".
One click to the right on the WONDERWHEEL to call up "Vehicle Settings".
You should then see Enduro Pro and Dynamic Pro on the list that pops up.
Scroll down using the WONDERWHEEL to highlight the one you want.
One click to the right on the WONDERWHEEL to get into the customization.
2018 GSA low tripple black
I got that. It's just not there. I only got the option of " pro" modes to cycle through. Cannot manipulate them.
Motor vehicle Automotive design Personal luxury car Auto part Gas
1 - 18 of 18 Posts
