I have a 2013 R1200 GS LC. I've searched as best I can, but most ESA posts seem to be related to the ride height aspect of the ESA. How can one verify the function of the damping adjustment on the ESA system. I commute to work regularly, so I have a nice repeatable route to evaluate such issues. The route has a rough, pothole and patched tar and gravel section and some nice new asphalt. I usually swith to "soft" on the gravel road and "normal" on the smooth. It seems the damping is no longer changing. It used to be very noticeable when I softened the suspension on the gravel, now it seems to be stuck in "normal" all the time. I have verified the ride height/spring preload adjuster works, I can see the adjuster move and the height does change. But the damping seems to be off. I don't have a GS911, but I do have the moto-scan tool.
