Hi, I'm working on my new-to-me 2009 BMW r1200gs. I bought some used Fastway footpegs circa 2009. They're in great shape. I cleaned them up. Installed the first one on the right side (rear brake side) of the bike, no problem. I went to the other side to take the factory peg off and I couldn't get the pin to slide out because the gear shift lever was in the way.
I searched the Internet to see if this was an issue others had had or if you need to remove the gear shift lever but I couldn't find anyone who had experienced this problem.
So, the question is, do you need to remove the gear shift lever on a 2009 r1200gs in order to remove the pin for the foot peg or is something else going on here? Only other possibility is that the foot peg bracket is bent...
Let me know if anyone has any experience with this. If I do need to take the gear shift lever off, would love some tips on that... Thanks
