1 - 2 of 2 Posts
Maybe, but there are plenty of universal aftermarket Quick Shifters out there that would probably be cheaper than the BMW one and work just as well. Frankly, the Shift assist is not as good on the GA/GSA bikes IMHO because the ratio gap between 1st and 2nd makes the bike jump when you make this shift. I usually use the clutch anyway. On the BMW K1600, the shift pro is brilliant and basically eliminates the clutch once you are under way and all shifts are very smooth.
1 - 2 of 2 Posts
