1 - 7 of 7 Posts
While it is a distinct pleasure to ride my R1250 GS HP, it is an annoyance that every time that I find myself in heavy traffic on a warm day (which is every day on my daily commute into NYC), it does not take long for the Faulty Spring Strut warning to take over my TFT display. The first time it happened, I believed it and brought the bike to a dealer to correct the fault. I was told that a recalibration of the strut was necessary and would solve the problem. The next time it happened, I was told by a different dealer to whom I had dutifully taken the bike for the repair that this was a known problem. Again, recalibration was the “cure.” The third time it happened, I asked the dealer if a fix of the “known problem” was in the works and was told that they had no info on a fix but that, as I had experienced, there was really nothing untoward going on with the spring strut on my bike. It was working normally. The warning was the product of an overheated sensor. No need to recalibrate.
The warning has occurred too many times to count since. I have learned to ignore it, but it is an annoyance. Anyone know anything different? Has anyone’s spring strut actually failed to work as intended? Anyone else getting tired of getting the warning?
Haven’t struck that warning on my R1250GS HP, but on my short commute I sometimes get warnings albeit for only a few seconds of over heating and to check the coolant levels. But I wonder if it’s related to your problem. At those times my right side calf can sometimes cook. Trying to find the source of the heat, I noticed the rear shock and reserve almost scorching hot. I have no idea where the sensor is, but maybe a heat shield of some sort might work. Not a lot of help I know but maybe this will trigger some others to chime in.
Strut warning light
https://ag.ny.gov/consumer-frauds/new-car-lemon-law-qa
I am loathe to suggest any legal action but you may find a faster solution/resolution by putting BMWNA on notice of a repeated safety issue with your motorcycle by sending them a certified letter indicating your desire to have this resolved before proceeding with other 'options' - give your dealer a heads up so they aren't blindsided.
It's not going to fix itself and I view any suspension malfunctions as extremely serious serious.
Good luck and safe travels
Is there no way to clear the screen when that happens? I've had the tire sensores taking over the screen saying that I need to check the tires. A real pain in the ass as you only can see the speed at that point.
Thanks. As I had stated, the problem is a false warning, not an actual suspension malfunction. The warning is an annoyance, nothing more as far as I can tell.
I would like BMW to fix the problem and expect that it will as, I understand from my dealer, this is a known issue. Please don’t anyone now recant on this thread horror stories of issues known by BMW in their cars and bikes that they did not address. I’m not naive.
Yes, as is the case with all warnings of a non life or bike damaging nature, a push of the Wunderlich wheel to the left clears the warning (but the yellow warning symbol stays lit until the bike is turned off). Still, the warning popping up while my left foot is baking and I’m stuck in slow or not moving traffic on a hot summer day is adding insult to injury (metaphorically). Hopefully, the mother ship in the fatherland will come up with a fix before long.
Haven't seen a 2019 up close and personal yet so cant compare to my 17. But didn't I read somewhere that BMW sort of rerouted the exhaust on the 19 models??
Maybe some exhaust heat wrap would help?
1 - 7 of 7 Posts
