1 - 7 of 7 Posts
Hi, looking for help on how to adjust the beam on my 2015 1200gs. It’s way too low, I’m out of ideas. Any help will be appreciated.
Cheers
Terry
Reach in behind the reflector assembly, the adjuster is a black plastic knob well tucked in there but not to hard to access.
Covered in my owner's manual under "Headlight Range Adjustment"
Reactions: Krons
That flip switch is for when you have the bike really loaded and then you can flip it, so you basically have 2 set points...there is an fine adjustment you can also do
28207
28206
1 - 7 of 7 Posts
