K1200S wheels (in black).
Looks very cool but the downside is that I have to change to sticky, sport bike tires that are limited to the pavement and will wear out more quickly. And, the speedometer reads about 5 mph too fast and the engine is turning higher rpm's
The engine won't turn higher RPMs - both the R-GS and K-S rear wheels are 17" diameter.
Rolling circumference MIGHT be an issue if there is a big variance in terms of tyre profile, but it won't be overly huge.
Having said that, if you want a slight reduction in cruising RPMs, why not try a 190/55-17 rear? Slightly taller profile.
The previous owner had to have the center and side stands modified to make this change as well as some slight machining of the wheels for track accuracy.
That's weird. My bike also uses a K1200S rear wheel. I've noticed no skewed tracking that would indicate too much 'meat' on the wheel hub for this application. There were no mods to my sidestand or centre stand, and there have been no tyre-clearance issues.
Having said that, I'm currently running a 180/55-17 rear tyre (as you rightly point out, the K1200S uses a 190/50-17 as standard).
Are there longer lasting sport bike tires that I could fit on this hybrid bike.
Anything billed as an 'everyday' or 'commuting' tyre will do fine.
I run a 110/80-19 Bridgestone Battlewing (to be replaced by a Michelin Pilot Road 3 Trail when it wears out) on the front, and a 180/55-17 Pilot Road 3 on the rear.
The one thing I can say about the wide rear wheel conversion - the turning stability is incredible. My old GSA (on wire wheels) used to get a bit flustered when I hacked it really hard around twisty roads. This thing? It just laps it up.
I would think you could fit a GS tire on the rear rim because the K1200s and R1200GS both run a 17" rear rim. (according to the info I found on the web) The K1200S runs a 190/50 17 The R1200GS runs a 150/70 17.
Trust me when I say that is NOT a good idea.
Modern bike tyres are each designed for rims of very specific width, and the tolerance for rim-width errors is about half an inch either way.
Any more than that, you're going to get flaky handling.
I don't Know if the rims are the same width, that would change the curve of the tire cross section, not always a big deal.
The standard GS rear rims (wire and alloy) are about 4" wide. The K1200S rear is 6".
Two inches variance in width is HUGE. Put it this way - if someone showed me a 150/70-17 tyre mounted on a K1200S rear rim, and offered me a ride, I'd politely refuse.
At the very least, you could find a little taller rear and fix the speedo issue.
Have a chat with your local dealer. I'm told there are software tweaks available to tune your speedo accuracy, especially in cases where wheel diameters have increased or decreased.
