Bumot has a large top case but it can't use the factory key
Givi also has a large top case
(I just posted this on the earlier post, forgetting I was no longer here… honey, where are my pills???)I know you are not found of DIY solutions, but have a look at my photo gear setup
If that 58L case is using the Givi to BMW factory mount, you can move it to sit over the passenger seat instead. If you look at the picture below, you can see the adapter plate the BMW cases use that bolt onto the main rack connected to the motorcycle frame. If you look at the main rack, just under the passenger seat, you will see there are two sets of vertical holes. These can be used to mount the adapter plate after removing the rear seat. The BMW Givi adapter plate should mount here as well, moving the case over the passenger area.Nope. Most folk use the Kappa Givi Trekker Outback/ K-Aventure (or whatever they're calling it today) 58 litre one. It's massive. Just be aware that using it will alter your bike's handling a bit and a lot if you overload it. It mounts too far aft IMO. I hate the fucking thing and rarely use it, so much so I mounted a small Pelican case on the mounting plate. It came with the bike when I purchased it. Use it as an ottoman now.
Got it. Perfectly clear and a nice simple solution.The aluminum cylinder is bolted (there is a self locking nut) from inside the case after installation. It pushes against the inside of the rack and hold the case in place.
Let me know if it is not clear, I'll get more pictures with the case on the bike.
I have the Bumot top case on my GSA with the OEM rack. It works just fine.As far as I can see, neither of those will interface with the factory mount. Both require replacement of the top mount, which means I cannot swap between the OEM topcase and the larger one without also changing the mount, which is what I was hoping to avoid.
