At least on the hexheads (pre-LC R1200GS), the varios offer a perfectly flat mounting platform if you remove the rear seat. Therefore I mount my luggage sideways and it is all well supported, without drilling into the varios. A pair of Rok Straps holds everything down. This way I can access pretty much everything without unloading.I have the Vario panniers on my GS. How does one fasten luggage on top of them without drilling holes for attachment points?
So, you want to attach bags lengthwise on you Varios ? In that case, you don't have many options without drilling holes and adding attching points.I asked the question for when I carry a pillion.
I found a way with an elastic strap around (see photo) and a strap between left and right in front of the top box, and one to the passenger footrest bracket. The solution was OK enough, but as I always travel with my wife, and after one season with the Varios, I found them to small and side loading a bit unpractical, I also don't like overloading them as several have mentioned. I decided to take the cost and have just recieved some Touratech Zega Evo X 45 L (silver). They seems great I like them, looking forward to put them on when the winter is gone. With the Touratech, you can still have the Vario support at the passenger footrest, the rack can easy be dismounted and the Vario's can be still be used.I have the Vario panniers on my GS. How does one fasten luggage on top of them without drilling holes for attachment points?
