1 - 16 of 16 Posts
I think a ghost is messing with my NAV VI...
Contacted Dealer, lets see what crazy thing they say...
Yep just got a replacement for mine. Thought it was just a dirty screen because when I would wipe it down it would behave again. Then one day riding to work it would just change screens by its self. Contacted Garmin and they sent me a UPS label and got a new one in about 2 weeks.
Mine was changing screens on me so I reseated it in the cradle and it's fixed. If you have a screen protector take it off and carefully cleen the screen. if it's still doing it do a factory reset.
I keep having to do a hard re-boot, which solves the problem for a while At least I know how to fix it, but a nuiscance.
Got the unit in....New Unit ID: 3999468024...was 3326029521...all other numbers match...as long as it doesn't rain we should be good to go a test run tomorrow...
I think what's happening when you see this kind of behavior could be that the CANBUS serial inputs from the controller wheel are floating or making intermittent contact. When I first put my Nav 6 on a cradle on another bike (no serial inputs) it behaved exactly like in your video. It would change screens randomly and sometimes ignore my inputs. Since I didn't need them anyway, I taped off the two pins for the serial bus and never had the problem again. If you want to do a very simple check to see if this is your problem, take a sliver of electrical tape and place it across the serial input pins as shown in this photo:
These should be the same pins on any Nav or Zumo cradle. This obviously isn't a solution for your problem because you need to use the multi-controller wheel but it'll isolate the problem to the GPS or the bike.
This is the opposite of what happened to mine. I was using some windshield cleaner (novus I think.....not about that) and used the cloth to wipe off the garmin. Total haywire after that. Never had a problem until I wiped it with cloth and cleaner. Garmin replaced it. Put a protector on it so we will see. If it does it again I will just ditch the whole deal and use one of the countless phone apps.
Discussion Starter #11
I removed the NAV VI from its cradle and it was still acting like a the bottom left was being pressed on the screen. My new replacement seems to be working well but we will see here in the near future.
This happened to me last Sunday. I called Garmin, they'll fix it. It will be my 2nd replacement unit, which I'll sell as soon as I get it. I'm going back to my old Nav V, which never gave me a lick of trouble. I'll put up with the dimmer screen in return for a unit that won't misbehave when I need it in the middle of nowhere.
2020 R1250GSA. Nav VI.
Ive been dealing with the infamous ghost issue too. I can get it to stop by resetting/rebooting the unit but after three different resets I finally called Garmin. The first question they asked was .... do you use heated gear? Anyway, I just got off the phone with them. They are sending me a brand new unit in exchange for my old one. Time will tell.
chuck
I get this problem if I don't ride often enough...combo of weather and schedule. I found that if I don't ride for 3-4 weeks, it loses charge and get the screen flipping until the battery in the Nav recharges. Sometime this take an hour or two. So, if I haven't ridden in a couple of weeks and know I'm going to ride the next day, I just plug it into a charge and no problems.
BTW, I have had one unit replaced for this problem.
1 - 16 of 16 Posts
