Hey folks! Glad to have found this forum, looking at tapping into some of the experience here. I've owned mostly newer sport bikes and worked on quite a few vintage Honda's..this would be my first 'adventure' bike.
So this bike has parked outside around the corner for a few years and I finally got curios about it and tracked down the owner. It's an 08 with 99k kilometres (hello from Canada) and needs work. I've got it to start with brake cleaner and have just removed the fuel pump housing to bench test the fuel pump - I think it might be bad because I never heard it prime. The FPC seems to check out - I measured ~9v when cranking.
The bike:
The major issue is the swingarm gaitors - they are worn and water is sitting inside. When I first tilted the bike upright water spilled out - how bad could the driveshaft be as a result?
Second major issue is that the owner reports he was only getting 10L/100km on the highway...fuely reports state folks get 5.5L on average...huge difference...any ideas?
Minor issues:
Other than that, electrical seems to be good, no hacks. Quite sun beaten overall but nothing seems brittle. Owner has luggage for it.
The figure we have tentatively settled on is $3000CDN...is this reasonable?
I'm a tall rider, 6'3" with 35" inseam. TY
The bike:
Minor issues:
- the top shock bolt is partially withdrawn and only holding on by 1 side of the frame.
- 1 screw missing from clutch slave cylinder - it rocks a little when clutch is pressed, not sure how long its been missing
- numerous dash warning lights..what is the absolute cheapest way to pull codes...there's an app similar to Torque but the interfaces are pricey?
- front and rear rotors have a noticeable lip, maybe close to 1mm, probably original?
- tires are DONE
- when I turn the ignition on, I hear rapid clicking from the rear shock for a second or two
